Cricut Maker Belt Replacement
Devyn White
crwdns2944107:0crwdnd2944107:0Devyn Whitecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 26, 2025crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
The belt of the Cricut Maker allows the machine to maneuver the blades and engraving tips along the desired material to produce desired patterns. If the belt is worn out or damaged, you may need to replace it.
If you find your machine will not sustain your patterns or the patterns are damaged or delayed, this replacement guide is for you!
Be sure to turn your Cricut Maker off and unplug it from the outlet before beginning this guide.
crwdns2944105:0crwdne2944105:0
  1. Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
  5. Cricut Maker Belt Replacement, Front Door Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement, Front Door Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
  8. Cricut Maker Belt Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
  9. Cricut Maker Belt Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Belt Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
  11. Cricut Maker Belt Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
  12. Cricut Maker Belt Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Belt Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
  14. Cricut Maker Belt Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
  15. Cricut Maker Belt Replacement, Motor: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement, Motor: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
  16. Cricut Maker Belt Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor by pulling it from the device.
  17. Cricut Maker Belt Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Under the motor there is a white plastic gear. To remove it, gently pull it off the axle.
  18. Cricut Maker Belt Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the washer from the top screw above the motor.
    • We found it was easier done by hand.
  19. Cricut Maker Belt Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5 mm screws from the remaining motor on the opposite side, using a Phillips #2 screwdriver.
  20. Cricut Maker Belt Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist and remove the motor from the machine.
    • Avoid touching the various tach disks on these motors.
  21. Cricut Maker Belt Replacement, Belt: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement, Belt: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement, Belt: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 10 mm screws using a Phillips #2 screwdriver.
  22. Cricut Maker Belt Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the belt holder towards you, and twist it sideways to slide it neatly into the same hole the belt is emerging from.
  23. Cricut Maker Belt Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the bar containing the axel and metal attachment out to remove them.
    • This should free the remaining side of the belt.
  24. Cricut Maker Belt Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the board on the main motor.
  25. Cricut Maker Belt Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the electrical tape from the connecting cable on the backside of the main motor.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Pull the cable out.
  26. Cricut Maker Belt Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 7 mm screws from the belt holder under the main motor.
    • Removing these two screws will cause the belt holder to detach.
    • Slip it through the hole in the main motor frame.
  27. Cricut Maker Belt Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Maker Belt Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the washer (e-clip) securing the bar to the belt holder.
    • We found it is easiest to remove by hand.
    • To remove it, simply twist and pull upwards to free it.
    • Remove the bar from the belt holder and then remove the belt holder.
    • Slip the belt out of the machine.
    That "washer" is properly known as an "E-clip".
    JCinGG - crwdns2934203:0crwdne2934203:0
    Where fo you get replacement belt
    Michelle Stone - crwdns2934203:0crwdne2934203:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Devyn White
crwdns2935283:009/20/22crwdne2935283:0
1,131 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 9-1, Watkins Fall 2022 crwdns2935289:0Austin Community College, Team 9-1, Watkins Fall 2022crwdne2935289:0
AUSTINCC-WATKINS-F22S9G1
crwdns2935297:027crwdne2935297:0
Where can I find the replace for the belt?
Adriahnna Sutton - crwdns2934203:0crwdne2934203:0
Hi… Where can I buy the replace for the belt? In Amazon I find one with this description
GT2 Pitch: 2mm
Belt Height: 1.38mm
Tooth Height: 0.75mm
Material: Rubber
Width: 6mm
Can you confirm if it is similar to the original machine?
Kerilacle - crwdns2934203:0crwdne2934203:0
Wie auch meine Vorredner, würde ich gerne wissen, ob du einen Link zu einem passenden Riemen bereitstellen kannst.
Beste Grüße
Martin Rathke - crwdns2934203:0crwdne2934203:0
No answer on where to buy 😵‍💫😵‍💫😵‍💫
Tina Amburn - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 176
crwdns2942667:0crwdne2942667:0 8,467
