Cracking the Case
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Cracking the Case, Cracking the Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down so that the three rubber pads are facing up.
  2. Cracking the Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. Cracking the Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. Cracking the Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cracking the Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. Cracking the Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cracking the Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cracking the Case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. Cracking the Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. Cracking the Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cracking the Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
Jared Everingham
crwdns2935283:001/23/14crwdne2935283:0
377 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-28, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 9-28, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S9G28
My product is On Stage I. It's too old. The screw fixing posts protruding from the plastic casing have broken on their own. As a result, the upper and lower shells cannot be completely sealed. When music is played, sound waves leak out of the gaps. It sounds thin and has no depth. It's like placing four speaker units directly outside the enclosure. Bass cannot resonate inside the enclosure, but travels through the bass hole in the middle. I really like this speaker. There's no way I'm giving it up. Is there any way to solve this? Should I look for a used case or use an existing case to rebuild the screw mounting posts? What should I do if I choose to rebuild?
怪醫杜立德 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 153
