The Cr-48 Chromebook is shipped with a combined Wi-Fi / Cellular network card that can be easily removed and replaced if necessary. In this guide, you will learn how to replace a malfunctioning network card in a Cr-48 Chromebook.
To take out the battery, slide the switch on the bottom of the laptop.
The battery should then pop out and you can remove it.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
Once you've removed the lower case, you should see the network card on the corner of the device containing the USB port.
Disconnect the Wire connections on the network card using forceps or tweezers.
Remove the screw (about 3 mm in length) securing the network card.
Pull the network card to remove it from the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
