Cowon iAudio U2 Display Screen Replacement
crwdns2942287:0crwdne2942287:0If you are not able to see anything on the screen, the device's display screen may need to be replaced.
crwdns2944105:0crwdne2944105:0
Unscrew the 4 screws using the PH000 drill bit from the iFixit toolkit.
Use the plastic opening tool from the iFixit toolkit to separate the back from the front of the device. This can be done by wedging the opening tool in the crack where the two sides of the device cover meet.
After it is wedged in push down on the exposed end until the two sides come apart.
Using the PH000 drill bit from the iFixit toolkit, unscrew the 2 screws that detach the motherboard from the device.
Using the plastic opening tool from the iFixit toolkit you will be able to wedge in between the device case and the motherboard. Push down on the exposed end of the device and the motherboard should pop up.
Pull the display screen off of the motherboard.
Slide the display screen chip out of the motherboard. Insert a new display screen.
My wife's Cowon iAudio U5's screen is displaying all white. When plugged into USB, I can see all the files. Do you think I need to replace the display, as in your instructions here, and where do you get a replacement display? Thanks. Ron.
