Core Assembly Removal
    1. Core Assembly Removal, Unfasten the back cover screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Before starting repairs, take your watch off the charger and power it down.
      • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
      • Don’t worry about removing the screws, they will stay in place in the back cover.
    2. Core Assembly Removal, Wedge open the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal, Wedge open the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert an opening tool between the back cover and the metal housing.
      • Twist the opening tool to create a wider gap.
      • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
    3. Core Assembly Removal, Disconnect the sensor flex cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Core Assembly Removal, Disconnect the sensor flex cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Core Assembly Removal, Disconnect the sensor flex cable: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lay the watch face down.
      • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    4. Core Assembly Removal, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal, Remove the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the back cover.
      • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
    1. Core Assembly Removal, Unplug the display connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal, Unplug the display connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
    2. Core Assembly Removal, Loosen the core assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal, Loosen the core assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The core's plastic frame fits tightly within the watch's metal housing.
      • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
      • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    3. Core Assembly Removal, Remove the core assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Core Assembly Removal, Remove the core assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Core Assembly Removal, Remove the core assembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully thread the display flex cable through the gap on the core's plastic frame.
      • Remove the core assembly.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
135.810 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:02.265crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 1,779
