Core Assembly Removal
crwdns2869540:0crwdne2869540:0: 1771
16
71
1.771
crwdns2955950:0crwdne2955950:0: 6
crwdns2960004:05crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 15 - 30 crwdns2931279:0crwdne2931279:0
Use this guide to remove the core assembly in your TicWatch Pro.
    1. Core Assembly Removal, Unfasten the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the four 3.9 mm-long Torx T3 screws.
      • Depending on the condition of your driver, a Torx T4 bit may fit better.
      • Don't try to detach the back cover yet. It is still connected to the watch assembly.
    2. Core Assembly Removal, Open the watch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal, Open the watch: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Be careful not to strain the sensor flex cable during this procedure.
      • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
    3. Core Assembly Removal, Disconnect the sensor cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal, Disconnect the sensor cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
    4. Core Assembly Removal, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back cover.
    1. Core Assembly Removal, Core Assembly Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 3.7 mm-long Phillips #00 screws.
    2. Core Assembly Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Core Assembly Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Core Assembly Removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
      • Use your spudger as a lever and pry up the core assembly.
      • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
    3. Core Assembly Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
      • Be careful not to strain the display and sensor flex cables during this procedure.
    4. Core Assembly Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
    5. Core Assembly Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Core Assembly Removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
    6. Core Assembly Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the core assembly.
Repair didn’t go as planned? Check out our Answers community for help.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
266.179 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2935297:072.885crwdne2935297:0
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
luciano.alonso84@gmail.com - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 71
crwdns2959996:0crwdne2959996:0 1,771
