Convert a 360 (Fat) hard drive into a 360 S hard drive
  1. crwdns2935267:0crwdne2935267:0
    Essential Electronics Toolkit
    $29.95
    • Toolkit change note: Due to the EET missing several bits present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET has everything needed to complete this guide if you already own one, but if you are shopping for a new toolkit to complete this for the first time, the Pro Tech Go or refurbished Pro Tech is the current recommended kit.
  2. Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • EET owners: Your kit has this bit. No purchase needed.
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  3. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disassembly tip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  4. Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  5. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
  6. Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you do not use an official hard drive, you will need a WD hard drive, the Xbox hard drive sector security file and HDDhackr to partition the drive. Partition 2 must be restored manually.
    • After removing the drive from the old enclosure, open the new enclosure.
    • Put the drive in the enclosure label side up. Space may need to be added for 7mm drives.
    • Close the enclosure and install it in your console.
Nick
crwdns2935283:011/10/09crwdne2935283:0
97,551 crwdns2915208:0crwdne2915208:0
crwdns2935297:061crwdne2935297:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 4,659
