Convert Sennheiser G2/G3/G4 radio antennas to SMA connectors
    • This guide will cover the removal of old antennas from Sennheiser G2 (and also some crossover with how the G3 system come apart)
    • I'll then describe how to prepare your parts for the addition if an SMA connector so you can use "whip" style antennae or wire in to a RF distribution system.
    • If you follow the first half of the guide it should be fairly obvious how to attach a Sennheiser part to the board should that be all you wish/need to do.
    • You will need at a minimum; a torx T6 driver bit and a soldering iron.
    • For the SMA mod you will need, in addition to the other bits, a pair of wire cutters and/or stripper, an SMA connector (RS part number: 512-0036), a file and a 1cm length of fairly thin wire.
    Hi,
    would be amazing to get pictures to this guide. Anyone?
    raaaeng84 - crwdns2934203:0crwdne2934203:0
    I'll be doing another couple of these sometime this month so will get some pics attached as I go through them.
    Charlie Hurst - crwdns2934203:0crwdne2934203:0
    • Using a small screwdriver (i.e. the Torx T6) just push the plastic bar and it should slide out the other side.
    • Now the cover should just come loose. It also separates all of the exterior components so you can take the back off without it pivoting around the bar!
    • Be careful of the two plastic pieces in the sides of the case. They aren't really attached to anything and are basically just spacers. Keep them safe on your parts tray.
    • Using a torx T6 driver bit unscrew each of the 4 screws pictured.
    • Put them somewhere they're not going to go missing; like an anti static tray or a magnetic mat.
    • Just one more T6 screw as pictured above. It's the top left screw if the pictures aren't available.
  1. crwdns2935267:0crwdne2935267:0
    Desoldering Pump
    $3.99
    • Hold your soldering iron on the solder point for a second and it should melt and come loose. If you have one use a solder sucker to clear the hole.
    • File or grind away the side of the SMA connector so that it will fit snuggly into the gap in the case.
    • I did this by hand a couple of times using the file on my multitool, but would recommend using a small power tool like a "Dremel" to speed up the process.
    • Cut a tiny piece of wire to length. Roughly 1cm.
    • Tin the ends and solder the small piece to the original antenna solder point on the board.
    • Solder the other end to the central pin on the SMA connector.
    • Before reassembling just make sure your solder joints are conducting correctly using a multimeter set to beep test.
    • Fit the connector in its snug little gap and follow the instructions in reverse to reassemble the chassis.
    • Add the retention nut to the top of the SMA connector to stop it from moving. this also provides a ground to the chassis once tightened.
Charlie Hurst
crwdns2935283:011/09/15crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
Hi Charlie!
After doing mods like this for a year or so, I decided that there needed to be a less labor-intensive solution, so I created an SMA antenna adapter that installs just like the stock antenna: SMA Antenna Adapter.
Tim
Tim Gooch - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,291
