Contour Roam2 Back Door Replacement
  1. Contour Roam2 Back Door Replacement, Record Slider: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Back Door Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Contour Roam2 Back Door Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Back Door Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Contour Roam2 Back Door Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Back Door Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Contour Roam2 Back Door Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Contour Roam2 Back Door Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Back Door Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
  6. Contour Roam2 Back Door Replacement, Mounting Piece: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Contour Roam2 Back Door Replacement, Mounting Piece: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
  7. Contour Roam2 Back Door Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Contour Roam2 Back Door Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the back door by your thumb and index finger on sides of back door and pull upward.
  8. Contour Roam2 Back Door Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your thumb, pry sides outward on back of mount piece.
    • This will loosen mount piece for removal in proceeding step.
    • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
  9. Contour Roam2 Back Door Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Contour Roam2 Back Door Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove and replace mount piece.
  10. Contour Roam2 Back Door Replacement, Back Door: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
    • After removing the metal bar, the spring will become loose and may fall out on its own.
  11. Contour Roam2 Back Door Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove and replace back door.
    • Door should easily be removed by pulling away from main body of camera.
    • As door is being pulled away, the spring may fall out own its own.
    Hey Great, guide I just had my back door snap on me, and will no doubt be using this guide to put it back together. Question though.. Where does one find replacement parts for a Contour2+ ? My searches have not turned up anything yet.
    Thanks,
    -Gman512
    Mark - crwdns2934203:0crwdne2934203:0
Jamie Maple
crwdns2935283:003/11/15crwdne2935283:0
310 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 4-5, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 4-5, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S4G5
Where can I get a replacement back door for an original contour roam shipped international? Contour will not reapond to my requests.
The Dude - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,749
