A 3AG fuse is a glass - bodied fuse designed to break an electric circuit if the current exceeds safety levels in a Commodore 64 device
1. Remove three 6.75mm ph2 screw heads from the casing
2. Split the case of the C64 open by pulling up on the case towards you
Good advice, but is there a reliable way of keeping the clips intact?
And probably never will fill it out.
1. Detach the multi-colored wire bundles that's connected to the motherboard
2. Find the 3AG fuse located next to the joystick ports and On/Off switch
3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
The fuse is 1.5 Amp, not 3
3AG does NOT mean a fast acting fuse. It could be either fast or slow blow. The 3 means it's 1 1/4 " long, the "A" means it has Axial connections, and the "G" means it's made of glass.
