Follow this guide to replace the drum expander of a Clarke EZ-8 floor sander.
crwdns2931653:01crwdne2931653:0 Disconnect all power cables
crwdns2944588:01crwdnd2944588:0crwdnd2944588:0crwdne2944588:0
Pull on the dust bag to remove it from the dust tube.
Pull up on the dust tube to remove it from the sander.
Gently lower the sander onto its left side (the side with the belt guard).
Lift the front cover up and out of the way of the sanding drum.
Pull the sandpaper loop straight up and remove it from the drum.
When in this position before removing the drum check the level of the wheels supporting the drum. Place machine on its left side and position right beneath to the left of the wheel is a 3/4 adjustable screw
Remove the 3/4" nyloc nut from the drum end plate.
Use a flathead screwdriver or a prying tool to pry up the key washer and remove it from the drive shaft.
Use the drum puller to loosen the drum and key washer so the key washer does not break. Do not go to far as to send the drum puller into the key washer.
Place the center screw of the drum puller onto the drive shaft of the sander and hook the puller jaws around the bottom end of the drum.
Use a 15/16" socket and an impact driver or a socket wrench to drive the screw of the drum puller clockwise, lifting the drum off the drive shaft.
Once the drum has been lifted about halfway off the shaft, it should move freely and can be lifted the rest of the way by hand.
crwdns2935229:013crwdne2935229:0
Tube Expander
the best product more details for mantion in this link
https://www.shingare.com/tube-tools/tube...
