Clarinet Cork Replacement
Hill Xiong
crwdns2944107:0crwdnd2944107:0Hill Xiongcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 20, 2025crwdne2944111:0
10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
Taking your clarinet to the music store to get your cork replace can be expensive. Following this guide by removing and replacing the cork yourself can save you a lot of money.
crwdns2944105:0crwdne2944105:0
  1. Clarinet Cork Replacement, Cork: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using pliers, remove the old cork by pinching it off.
    • Make sure not to push too hard with the pliers, as you can crack or chip the structure.
  2. Clarinet Cork Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean the joint with soap and water
  3. Clarinet Cork Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Measure the width of the tenon joint.
    • Only measure the area where the cork will lie, not the entire joint.
  4. Clarinet Cork Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the new cork to match the width of the tenon joint.
  5. Clarinet Cork Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the backside of the cork to reveal the adhesive.
  6. Clarinet Cork Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wrap the cork around the joint.
  7. Clarinet Cork Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Sand the cork with sandpaper until the cork is smooth.
  8. Clarinet Cork Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply cork grease on the new cork.
  9. Clarinet Cork Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly twist and slide the joint back together.
Once your clarinet is reassembled, leave the joint together for at least a few hours to let the cork compress and adhere properly. Play the fully assembled clarinet or blow some air through the joint to check for any leaks. When you are ready to put it away, disassemble it carefully. Enjoy your new cork!
crwdns2935229:08crwdne2935229:0
Hill Xiong
crwdns2935283:010/26/17crwdne2935283:0
278 crwdns2915208:0crwdne2915208:0
UC Santa Barbara, Team S3-G1, Weedon Fall 2017 crwdns2935289:0UC Santa Barbara, Team S3-G1, Weedon Fall 2017crwdne2935289:0
UCSB-WEEDON-F17S3G1
Where do you buy the corks from? Could you post a link to them?
Joshua Leung - crwdns2934203:0crwdne2934203:0
Make sure to use sandpaper with around 60 - 80 grit
[deleted] - crwdns2934203:0crwdne2934203:0
Wat if the cork strips don't have adhesive.wat do I use
kendall mckenzie - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 14,955
