Casdon Dyson Ball Ball Motor Replacement
  1. Casdon Dyson Ball Ball Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
    It take 4 C batteries. Hope this helps!
    Ladii Lee - crwdns2934203:0crwdne2934203:0
  3. Casdon Dyson Ball Ball Motor Replacement, Casdon Dyson Ball Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
    There is a clip inside the lip on the front side that needs to be overcome. I used a flathead screwdriver through the gap to help lift the corner of the clip.
    Garrett - crwdns2934203:0crwdne2934203:0
  7. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove beads from the container.
  8. Casdon Dyson Ball Ball Motor Replacement, Ball Motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 11.5mm (0.45 in) screws at bottom of bead cylinder container using the PH00 screwdriver.
  9. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bead cylinder and motor mount from the vacuum ball.
  10. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the motor mount from the bead cylinder by pulling the motor mount away from the bead cylinder.
  11. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the fan from the motor shaft by pulling the fan away from the motor.
  12. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the wires to the faulty motor using wire cutters.
  13. Casdon Dyson Ball Ball Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove and replace the faulty ball motor with a new one.
    • Solder the new ball motor's wires to the vacuum's wires which were previously cut.
Seldon Price
crwdns2935283:011/07/17crwdne2935283:0
612 crwdns2915208:0crwdne2915208:0
IUPUI, Team S3-G5, Harley Fall 2017 crwdns2935289:0IUPUI, Team S3-G5, Harley Fall 2017crwdne2935289:0
IUPUI-HARLEY-F17S3G5
Thank you for the guide, it helped me successfully repair the top motor that stirs the colored pellets. My son will be so happy to see it working again!
crwdns2942667:0crwdne2942667:0 743
