This replacement guide of the motor involves one phillips PH00 screwdriver and use of a soldering tool. The plastic pieces are fragile, so be careful of using excessive force when taking apart the product.
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove batteries from the vacuum by pulling them out and away from the vacuum.
Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
Remove the front side covers by pulling them away from the vacuum.
Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
There is a clip inside the lip on the front side that needs to be overcome. I used a flathead screwdriver through the gap to help lift the corner of the clip.
Remove four 9.2mm (0.32 in) screws on bottom of air cylinder motor mount using the PH00 screwdriver.
Remove one 11.5mm (0.45 in) screw in battery compartment using the PH00 screwdriver.
Remove the red fan from the motor by pulling the red fan away from the bead cylinder motor compartment.
Cut wires connected to faulty motor using a set of wire cutters.
Remove and replace faulty air cylinder motor.
