Carrera Mario Copter Controller Circuit Board Replacement
  1. Carrera Mario Copter Controller Circuit Board Replacement, Controller Circuit Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the controller over so the underside would face up
    • Remove four of 7.1mm screws with a JIS #1 screwdriver
    • Remove two 4.0mm screws located on the handle with the JIS #1screwdriver.
    • Remove two 7.1 mm screws on the small area that stick out from the surface with the JIS #1 screwdriver
    • Use an extension with the JIS #1 screwdriver in order to get to the screws with yellow marks because they locate deep inside the holes.
  2. Carrera Mario Copter Controller Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black case to access the circuit board.
    • Remove two 4.8mm screws on the circuit board with the JIS #1 screwdriver.
  3. Carrera Mario Copter Controller Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up the circuit board from the black case.
    • Use a soldering iron to melt the red wire while at the same time pulling it from the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Repeat the previous procedure with the black wire.
    • Gently remove the circuit board away from the case.
Edgar Lopez-Allende
crwdns2935283:010/20/17crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G6, Rose Fall 2017 crwdns2935289:0UW Tacoma, Team S1-G6, Rose Fall 2017crwdne2935289:0
UWT-ROSE-F17S1G6
crwdns2935297:011crwdne2935297:0
i don't have the receiver. what can i pair with?
Ali Ali - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 322
