The Canon Selphy CP910 is used to print pictures from a camera and WiFi connection. For information regarding troubleshooting issues with the Canon Selphy CP910, go to Canon Selphy CP910 Troubleshooting.
A new ink cartridge will be necessary to replace the old ink cartridge from the Canon Selphy CP910. Click here to purchase a new ink cartridge through Canon's website.
Open the door to the ink cartridge located on the right-hand side of the printer.
Lift the brown "eject" button up with your finger.
Use two fingers to pull out device.
Pull out the empty ink cartridge and exchange it with a new one.
Push in new ink cartridge and close the lid.
What if the cartridge is still functioning before malfunctioning, not as finished catridge but needed firmness.
My printer ask for replace ink catridge, which I did and it still tells me that the ink catridge ( which is new ) still needs a catridge
As above comment from Paul Soo, I too have replaced the cartridge with a new one and it still says I need a new cartridge.
Lindagz59@gmail.com
Thank you! So simple to follow these instructions!
As above fitted new cartridge purchased from Cannon still getting same message ink cartridges empty replace cartridge tried numerous times no joy Help
Ink cartridge replacement done with three new purchases
What the heck is going on?
HELP
crwdns2947412:028crwdne2947412:0
My cp910 keep prompting ink cassette is empty even though I have inserted new ink cassette. I tried two new ink cassette, same error msg.
me too! i have the same problem
I have the same problem with my CP910???
I’ve inserted a new ink cartridge but now the printer won’t pick up the print paper to print the picture! I keep getting the same error message saying “no paper or cassette incorrectly inserted! Now, the new ink cartridge won’t eject either! HELP!
I have the same problem. Any solution?
My ink catridge was tear apart. Should I replace it with the new one? Please help me. I want to use it as soon as possible.
Same problema, ink cartridges empty
Same problema, ink cartridges is empty.
I've insert new
Any solutions??? me too, it keeps telling me busy, paper sounds like loading, then says to replace ink. I JUST DID, three times
so many user complaining the same problem but no 1 from canon could help? come on
Has anyone found a resolution for this? Having the same challenges
Seems like a major design flaw. I have had the same issue with two different Selphy's. Called Canon support and they just told me it was dead and I needed a new one. They said if it was under warranty I could get it fixed for free. I've only used this for less than 100 sheets of paper in the past 2 years and it's out of warranty so I lose. They did offer to let me have a replacement at a reduced price. When they told me the reduced price I realized it was $20 cheaper at B&H. They then offered to match B and H price. so they really is no reduced-price they're just trying to sell you another printer. I find that very sad from a big company like Canon to not support this. And I do believe this is a widespread issue and they are really not taking responsibility nor fixing it.
We should do a survey and see how many of us have this problem and make some kind of a formal complaint to Canon to get it fixed
canon selphy cp900 ink cassette is empty error
I have the same problem after trying 2 new cartridges. Bad product. Zach
im facing the same problem, changed 2 new ink cartridges so far and still getting the same “epmty ink” error !! thats so frustrating !
I keep getting an error message saying “Ink Cassette is Empty” when I have just inserted a brand new Canon cassette. I spent over $80.00 in ink thinking it was just a bad cassette. Canon needs to address this issue.
I also called canon service but they will charge you half of the new machine cost for issue checking only. If you have to replace some parts, they will charge you the repairing cost. They don’t want to share any information what the root cause is. They just ask you to take machine to them for repair. I did disassemble the machine but cannot find anything wrong.
Someone found the solution and I tried it and it can fix this problem. Printer still indicate low ink?
I was printing and I ran out of ink I replaced the cartridge and now it won’t print. No error message nothing, the screen comes on it just doesn’t do anything. Can anyone help?
Check out the repair that covers the gear on the end of the motor shaft. Frequently falls off. Needs gluing on!
I’ve replaced the ink cartridge and the error message didn’t go away. I still can’t print.
Has a solution been found for this issue - still a problem in 2021!!!
Just a thought.. I came to this page looking for a solution. My printer was coming up with endless error messages about the wrong size of paper or ink cartridge. Make sure the printer is on a flat surface, and the paper tray isn't dangling off the side of the table. Try squeezing the ink cartridge firmly as far as it will go into the printer while it is preparing to print. A combination of these things seemed to work!
No, still doesn't work.. and my husband just ripped off the new ink I inserted in 😭
It's 12 April 2022 and still no one can solve the problems? Poor product!
Mine too behaving in the some any solution,?
The solution is here. Easy to repair. Poor design. Poor quality. A shame for Canon.
Hello here,
we have an error message saying: "paper jam", but there is no paper in the printer. and when I try to eject the ink cartridge to have a look inside the printer, the ink cartridge won’t eject... is there anybody able to help here please ?
