Canon PowerShot G12 Rear Function Setting Dial Replacement
  1. Canon PowerShot G12 Rear Function Setting Dial Replacement, Rear Function Setting Dial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws on the bottom of the camera using a Phillips-head 00 screwdriver.
    In this guide, the LCD panel has been removed. It is not necessary to do this in order to remove the rear panel. Just fold it open and you can leave it attached.
    jnbruin - crwdns2934203:0crwdne2934203:0
  2. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all of the screws on both the left and right side of the camera.
  3. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Looking at the front side of the camera, there is a port on left side of the camera labeled HDMI.
    • Remove the one screw on the side of the HDMI port.
    There is also another screw hidden by a left thumb.
    Philip Knowles - crwdns2934203:0crwdne2934203:0
  4. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw on the right side of the view finder on the back side of the camera.
    This screw is sometimes hidden inside of the access hole and can only be loosened from the outside of the camera. In order to fully remove it, you will have to partly remove the camera back assembly as the screw head is too large to pass through the access hole.
  5. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, carefully pry open the back side of the camera starting directly under the camera's serial label.
    • Make sure all sides of the back case are loose before trying to force it off of the camera. It should be removed with relatively little effort.
  6. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back case is still attached to the camera with a yellow ribbon cable. The socket has a black flip-up lid that must be flipped up before the cable can be removed. Use precision tweezers to remove the cable.
  7. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the camera aside and look to the interior to the camera's back shell.
    • Peel off the thick, plastic seal over the metal plate near the yellow ribbon cable.
  8. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws from the metal plate using a Phillips-head 00 screwdriver.
  9. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the spring from its socket using precision tweezers allowing the metal plate with the function dial to be removed.
  10. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using precision tweezers, pry the old function dial out of its socket leaving only a black, metal ring attached.
  11. Canon PowerShot G12 Rear Function Setting Dial Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the new function dial simply by pressing it into the black, metal ring until you hear a click.
Alexandra Millett
crwdns2935283:002/23/15crwdne2935283:0
345 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-5, Leahy Winter 2015 crwdns2935289:0USF Tampa, Team 1-5, Leahy Winter 2015crwdne2935289:0
USFT-LEAHY-W15S1G5
Thank you so much!! I needed to replace the entire rear cover, because Canon doesn't sale just the wheel separately. your guide was the best one I found on the web. I think you ought to make a video of it, I admit I didn't see the "black flip-up" in part 6 so that part (putting the cable back in) was the most aggravating part for me.
But again thank you so much!
Maya Shemolewitz - crwdns2934203:0crwdne2934203:0
Very good guide, the only one I’ve seen so far. Thanks for that>
Philip Knowles
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 3,456
