Open the LCD screen of the camera
Rotate the screen so that it is perpendicular to the body of the camera
Remove the .2mm screw using a Phillips #00 screwdriver
Rotate screen 180 degrees and remove second .2mm screw
Gently remove the back panel of the LCD screen
Once the back panel is removed another .2mm screw will be revealed, remove this screw to remove the front panel of the LCD screen
Gently remove front panel of the LCD screen
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Locate the ribbon (orange) and using tweezers gently pull back the retaining clip and pull the ribbon out
Use a spudger to gently remove the LCD screen from the metal backing plate
Where can I purchase a replacement LCD screen?
I have the same question!
