Locate and remove the clock battery from the camera.
While the switch is pushed forward, pull the cover away from the camera.
To remove batteries, simply allow them to fall out of the camera.
Use a fingernail to lift the clock battery out of the camera.
To access the clock battery, find the clock battery cover, shown here in the red square.
When accessing the clock battery, use a fingernail or similar small instrument to gently pull the tab out.
Now that you have the tab and battery removed, use a fingernail or other small tool to remove the battery from the tab.
This battery is a CR1220 type watch battery.
crwdns2935229:013crwdne2935229:0
crwdns2947412:09crwdne2947412:0
thanks its very useful forme
thank you, very useful for my old camera :)
Perfect! I never even knew I had this battery in there. Couldn't figure out why the date and time wouldn't stay set every time I shut it off. And then I found the answer here.
Thank you very much for the post!
I'm a senior citizen and am not very good with modern technology. Been going crazy trying to set my clock in my digital camera. I didn't want to buy a new one because I have had this one for years (Power Shot A590) and didn't want to have to learn to use a newer one. Finally got smart enough to do a google search for an answer. Will get a new battery tomorrow and solve my problem. Thanks for the help!...the information age is good for something after all.
Wow this is a great site. I got the answer I needed right away. The instructions were clear, simple and correct. Thank you.
You are bookmarked.
Please has anyone got a clock battery holder for a powershot A590? Mine fell out somewhere
when the kids were using it Love the camera and would like to get it back in use
Email at acv@xtra.co.nz if you could help me
rgds Alan
I had this annoying problem for two years and thought a lot of disassembly would be required to access this battery, so I lived with it. I was glad I came across this site and never realized that the lithium battery cover was so easily accessed. I easily replaced the CR1220 battery and now have my time/date back.
Bonjour, j'me nomme ATOULOUKOU, j'suis un utilisateur de l'appareil photo canon A580, ça fait un vieux que j'l'ai maintenant, Euuh j'me suis acheté une pile duracell, il y'a 2 jours de cela et j'ai remplacé les anciennes piles par les nouvelle mais j'constate que mon appel affiche tjrs la batterie faible et me conseille de changer les piles j'sais pas si ce sont les piles nouvellement achetée où bien l'appareil à un blême ( peut-être qu'il y'a une batterie incorporée à l'intérieur qui est faible ) bah j'sais pas, donc j'aimerais que vous m'aidez sur ce problème
Hello, my name is ATOULOUKOU, I am a user of the Canon A580 camera, it's been an old one that I have now, Uh, I bought myself a duracell battery, 2 days ago that and I replaced the old batteries with the new ones but I noticed that my call always shows the low battery and advises me to change the batteries I don't know if these are the newly purchased batteries or the device has a pale (maybe there is a built-in battery inside which is weak) well I don't know, so I would like you to help me with this problem
Can the hatch be replaced. The piece that holds the hatch is broken.
alisonbforman46 - crwdns2934203:0crwdne2934203:0
I had this issue for some time and never realized that lithium battery was so easily accessible. Fixed my problem.
Spud Head - crwdns2934203:0crwdne2934203:0
