You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
While the switch is pushed forward, pull the cover away from the camera.
To remove batteries, simply allow them to fall out of the camera.
Use a fingernail to lift the clock battery out of the camera.
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
Open the battery cover.
Using the iFixit opening tool, push up gently around all edges of the camera.
Ik kan de achterkant er niet afkrijgen.
De onderzijde gaat wel wat open, maar wat ik ook probeer de bovenzijde blijft op de een of andere manier haken en geeft geen krimp.
Hopelijk hooft iemand hier iets op verzonnen om hem wel open te kunnen krijgen.
mvrgr WH
crwdns2935229:08crwdne2935229:0
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Can the hatch be replaced. The piece that holds the hatch is broken.
alisonbforman46 - crwdns2934203:0crwdne2934203:0
I had this issue for some time and never realized that lithium battery was so easily accessible. Fixed my problem.
Spud Head - crwdns2934203:0crwdne2934203:0
