Canon ImageCLASS MF4350d Scanner Disassembly
  1. Canon ImageCLASS MF4350d Scanner Disassembly, Scanner Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon ImageCLASS MF4350d Scanner Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
crwdns2935229:05crwdne2935229:0
Tanner Papenfuss
crwdns2935283:009/30/13crwdne2935283:0
572 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-1, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 13-1, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S13G1
The paper tore and is now not visible. How do I remove the printer's components to access the paper deep in the machine? Is there a method to factory reset the machine? Can I somehow make the rollers rotate to attempt to pushing the paper out?
Kyle - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,353
