Canon EOS Rebel XS 35mm Back Latch Replacement
  1. Canon EOS Rebel XS 35mm Back Latch Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the six screws from the base of the camera.
    • Use a Phillips #000 screwdriver to remove the 7 mm screw.
    • Use a Phillips #000 screwdriver to remove the 7 mm screw and the five 4 mm screws.
  2. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the six screws from the base of the camera. Then, push the bottom cover toward the back of the camera with your fingers until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers or your fingers, carefully remove the five gears and set them aside temporarily.
    • Using tweezers or your fingers, carefully remove the five gears and set them aside temporarily. These gears can fall out easily while you’re working, so keeping them organized will help prevent loss.
  4. Canon EOS Rebel XS 35mm Back Latch Replacement, Top Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement, Top Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  5. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  6. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the front cover.
  7. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  8. Canon EOS Rebel XS 35mm Back Latch Replacement, Back Latch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the front, top, and bottom covers have all been removed, it's time to remove the back latch! Using a paperclip or something similar (anything that's very skinny), push on the end of the skinny, silver, metal rod that vertically travels through the camera. Do this until enough of the rod pops out on the other side for the next step.
  9. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the screw with #00 screwdriver
    • Unscrew the screw with a #000 Screwdriver
  10. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully after unscrewed, remove the side piece to open latch
    • Carefully hold camera around and not on the camera sensor
  11. Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel XS 35mm Back Latch Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a pair of tweezers or just your fingers, pull the rod completely out of the camera. The back latch should then completely detach from the camera.
christiansvezia
crwdns2935283:010/24/18crwdne2935283:0
1.136 crwdns2915208:0crwdne2915208:0
This would be fantastic if only you'd noted a place to obtain a replacement latch from.
David Sanborn - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 1,041
