The control dial on the canon EOS A2 lies underneath the top cover of the device. The front cover must also be removed in order to access this.
Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
Remove the battery from inside the battery housing and set the cover aside.
Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
Remove the 6.4mm screw from the inside of the flash bezel.
I have the problem that I cannot turn the camera on because the rotary switch turns freely, therefor I cannot open the flash to get to the screw that needs to be removed in order to fix the rotary switch. In the rotary switch photo you suggest using a pencil to turn it but in the photo the cap of the switch is removed. How do you remove this cap? I have tried prying it off but no success.
Tu peux tourner le commutateur rotatif même sans enlever la vis du flash. Il m’est arrivé le même problème, pour cela j’ai dévissé tout ce que je pouvais. Ensuite, en soulevant au maximum le couvercle supérieur, tu peux voir cette partie métallique par en dessous et la faire tourner avec une objet très fin jusqu’a atteindre un point de buté, ce sera 125. Ensuite tu mets la batterie, appuie sur le bouton flash et c’est ok normalement. Le fait que la molette tourne dans le vide est du a un tout petit ressort cassé.
Fr c -
i also have this same problem and i tried to follow your instructions to unscrew what i could then take off the top, but it seems like it will not come off without the flash being up. which i can not do since i cant turn the camera on. what do i do?
Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
Remove the 5.6mm screws behind the battery cover.
Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
Remove the 6.4mm screw on the top of the inside edge of the battery hole.
Remove the 4.3mm screw below the camera strap ring.
Remove two 4.8mm screws located on both sides of the eyepiece.
Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
Remove the 3mm screw from the back of the control dial while holding the front of the control dial.
On the bottom side of the top bezel, remove the ring, detent ball and spring. Your control dial is now ready to be replaced with a working unit.
Could anybody explain how this spring and ball are placed inside ?
crwdns2947412:09crwdne2947412:0
Is it safe to do this procedure while a film is inside the camera?
I was wondering if anyone could help me were I could possibly get the new parts?
I've looked around but found nothing relevant so far.
Thanks in advance,
Agoston Horanyi
Did you find the parts ? If no go to eBay.
as exemple : https://www.ebay.com/itm/Canon-EOS-A2E-R...
gilberto -
I'm wondering if there is someone who can fix the mode selector for a reasonable price
How can I open the flash to get to the screw that needs to be removed in order to fix the rotary dial when the rotary dial is moving freely and the camera does not turn on?
You must insert the battery into the camera, turn it on, then press the flash button to open it. Be sure to remove the battery afterward!
i had the same issue (control dial was locked up when i got it), and to be honest i just kinda pulled it up 😳 it felt a little wrong but it didnt break anything and the camera works like a charm now :-D
I Malloy -
Hello, can someone tell me the exact position of the detent ball in step 16? Thanks
Yes, my issue also. Plus where does that mini spring go upon assembly? Would be very grateful for a detailed reply. Thx in advance
Alberto -
