Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement
  1. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement, Card reader: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First the outside screws need to be taken off. Start with the three screws on the left of the camera (looking from the back).
    • To get to these screws, the front rubber pieces will need to be removed. Run a plastic opener under the edge, and peel the rest off.
    • Once the rubber is off, remove the top two screws pictured
  2. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the top two are removed, the bottom one must be removed.
    • Open the port covers to gain access to the screw, and remove it.
  3. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Three screws on the bottom need to be removed next. They can be removed in any order
  4. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The top 4 screws need to be removed next. They are located behind the eyepiece.
    • Remove the eyepiece by squeezing the sides and pulling up
    • Once it's removed, you will be able to see the 4 screws.
    • Remove these 4 in any order
    • The final screw securing the back of the camera is located under the thumb grip rubber. Using the same process, peel back the rubber starting from the top.
    • The entire piece does not need to be removed, just enough to reveal the final screw well
    • Once access is gained to the final screw remove it.
    • At this point, the back is ready to be removed.
    • Do not pull up hard, as there is still a cable attached. Instead, slide a plastic opener along the bottom and open up until you can see the flex cable securing the back.
  5. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the connecting flex cable, something can be used to hold it up (CF card was used in the example photo), or simply hold it up with another hand
    • Use a plastic opener to pry the bottom connector out of the socket.
    • Once disconnected, lift up the back and set it aside, it will not be needed until reassembly.
  6. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The two screws securing the logic board shield need to be removed next.
    • The shield can then be lifted off, revealing the dual Digic 4 processors.
  7. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now, the flex cables need to be disconnected.
    • There is no particular order they need to be disconnected in, as long as they all are disconnected.
    • Upon reassembly, it helps to swab all the contacts at the end of the cables with a degreaser such as Isopropyl alcohol.
    • Most of the cables can be disconnected by flipping up a tightening bar.
    • To do so, insert a plastic opening tool under the edge and pry up
    • Now that the cable is lose, use tweezers or just simply your fingers to pull out the cable.
  8. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The two middle cables need to be removed next. Use the same process as before, or if no tightening bar is present, gently pull the cable straight out.
  9. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the largest flex cable connecting the sensor to the board.
    • Use a plastic opening tool
  10. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next to remove is the bottom left corner flex cable. It has no tightening bar, so pull it out with tweezers or with your fingers.
  11. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top right corner cable. It also has no bar, and can be pulled straight out. Move it out of the way.
    • This will give access to the cable underneath, which can be removed next
    • Flip up the bar, and pull out the cable.
  12. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The red and black power cable can be removed next. It it different than the rest, and can be removed by either using a plastic opening tool or a very small pair of pliers to remove it.
  13. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The final cable to be removed is in the top right corner.
    • Flip up the bar and pull it out.
  14. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that all the cables are disconnected, the screws must be removed.
    • Remove all of the marked screws securing the board.
  15. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The board now is ready to come out. It has a connector on the top right, so it cannot be pulled out quickly. Instead, slide a plastic opening tool under the top right of the board, and pry up.
    • Once the connector is disconnected, carefully remove the board and set it aside.
    • Reassembly: Make sure the black tube goes into the slot on the board, it's easy to miss.
    Note on 17 C picture the board is removed and flipped upsidedown to show where the optical black tube inserts on re-assembly
    Paul Ardolino - crwdns2934203:0crwdne2934203:0
  16. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the main board gone, the removal of the card reader can begin.
    • Remove the first two screws securing the reader.
    • Then remove the bottom final screw securing the reader
  17. Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS 7D Bent CF Pin Fix/Card Reader Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The card reader can now be removed
    • Start by pushing the card reader in from the outside slot.
    • Once it's lose, lift the card reader out vertically
    • Insert the new part into the slot, and follow all the steps backwards. See notes for reassembly
    In the photo for step 19, the pin board is attached to the card-reader slot. How are these connected? On e-Bay, I only see the pin board available for purchase (not the entire slot).
    Looking forward to getting this done! Canon online estimated $175 for this repair plus a cleaning.
    jessematthew@gmail.com
    Jesse Adams - crwdns2934203:0crwdne2934203:0
crwdns2935229:024crwdne2935229:0
Nick
crwdns2935283:003/10/14crwdne2935283:0
814 crwdns2915208:0crwdne2915208:0
crwdns2947412:019crwdne2947412:0
I am so grateful for this guide! The directions and photos are crystal clear. Every step is thoroughly yet simply explained. I saved about $350 on this repair.
Mikel - crwdns2934203:0crwdne2934203:0
Excellent guide! Some additional tips:
1. be extra sure that you've seated the ribbon connectors securely and correctly. I didn't and got an "Err 20". I disassembled, cleaned ribbons with alcohol, reassembled and it was fine.
2. It would be great if there was some pictures for removing the actual connector for the CF card from the housing. It was a little tricky but practicing using the old broken one will help you to seat the new one correctly.
Dave Dal Pos - crwdns2934203:0crwdne2934203:0
Great guide. I was successful with my fix. A few more tips:
1. Eyepiece removal -- squeeze sides and SLIDE it upward toward the top of the camera.
2. Use a magnetic or slightly magnetized screw driver. On one of the tiny internal screws it came off my screw driver and dropped into the internals of the camera. I thought I was doomed, but after removing the main board and by carefully lifting and tilting the camera, I was able to find and retrieve it with tweezers.
3. When removing ribbon cables, the tightening bar flips up and the ribbon cable slides out (don't lift upward, slide it back toward the direction the cable comes from).
4. In step 13, I think he means "top left" corner and on my camera both cables had a tightening bar.
5. When reinserting the ribbon cables, I found it very helpful to use the tiny whole in the cable and pair of pointed tweezers to gently "squeeze" the ribbon cable into the connector. This also helped it go in straight.
Hardy - crwdns2934203:0crwdne2934203:0
After I reinstalled everything, I put in the battery, the empty battery signal blinking even on full charge.
nothing else showing.
Anyone know which part went wrong?
wendy - crwdns2934203:0crwdne2934203:0
I have this same problem, where I'm stuck is with the main flex cable, which looks like it's not connected to anything.. help?
Sebastian Zamora -
I think you should check the connection behind the main board (the power connector which slots in the power circuit under the top LCD)
Anri -
there is a video for doing this for a canon 5d mark I on youtube
pilgram driver - crwdns2934203:0crwdne2934203:0
Thank you thank you.... I made few mistakes.... one of the cable got detached and I have to tear my camera apart to be able to fix the cable that was going underneath the bottom....
Everything is working well now ! Thank you very much
Next time I will do it differently. I will draw on a piece of paper what I see and put a needle hole on each screw on the paper to place the screw inside it.
The screws come on different size so it is important to know where goes each. I had more screw to unscrew that what it was initially planned.
Patricia - crwdns2934203:0crwdne2934203:0
In step 1, how is the "rubber" part of the camera attached to the body? Double side tape or does it "snap" into the body? I'm curious as to how the rubber reattaches to the body of the camera w/o falling apart or feeling loose once you reassemble it.
Thanks
Chris Nguyen -
forgive my ignorance, but i have the same problem on my 6d, the process would be the same right?
bogusha bargiel - crwdns2934203:0crwdne2934203:0
Hi guys, can someone please give me the link for the actual part? I can’t seem to find it! Thanks!
Arabel C - crwdns2934203:0crwdne2934203:0
Whilst I haven’t had to do this it is an excellent guide.. wish he’d done one one on the control knob and switch
Michael Cooper - crwdns2934203:0crwdne2934203:0
Used this manual, thanks! I only replaced the pin part of the card reader, so with minimal expenses, 1hr of precision wrenching.
Robin van Dijk - crwdns2934203:0crwdne2934203:0
Hey Nick, would this work for a Canon Rebel XT camera?
Kyle Wilhite - crwdns2934203:0crwdne2934203:0
Also, what is the name of the specific part?
Crazy helpful.
1. Beneath the connectors and board seen in Step 10 is a loose-looking connector that threw me, but apparently it’s supposed to be loose.
2. The board connector mentioned in Step 17 needs to be pressed intentionally. I failed to do this and couldn’t power up. Re-did everything and discovered my error.
Thanks much!
Thank you so much for posting this! I was able to get the part swapped out and fixed in under 1.5 hours. This saved me so much money!
Hugo Le Du - crwdns2934203:0crwdne2934203:0
So glad I found this guide! Had one of these cameras come into my shop for this PRECISE repair. I was amazed to find this guide and the instructions were clear, concise, and easy to follow! Kudos to the auther!
Jeffery Haulk - crwdns2934203:0crwdne2934203:0
This is very educative. I will like to know to replace the lens holder as mine broken. I also need information from where to buy a replacement
Otega Ididia - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 155
crwdns2942667:0crwdne2942667:0 41,821
