Canon EOS 60D Rubber grips Replacement
  1. Canon EOS 60D Rubber grips Replacement, Rubber grips: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
crwdns2935229:010crwdne2935229:0
Eric D
crwdns2935283:011/13/12crwdne2935283:0
1 377 crwdns2915208:0crwdne2915208:0
Where can we get replacement grips?
Luke Lin - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 12,207
