Canon EOS 40D Date and Time Battery Replacement
crwdns2942287:0crwdne2942287:0If your date and time battery needs to be replaced, follow this guide to replace it. The required date and time battery is a CR2016 lithium.
Locate the battery compartment cover on the bottom of the camera below the shutter button.
Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
Release the lever and allow the battery compartment cover to completely open.
Remove the battery.
Remove the date and time battery holder by sliding it out of the slot.
Remove the date and time battery from the battery holder.
Thank you! Very easy to follow - helps to have a little tool to pull the battery holder out but not hard at all!
Mil gracias!! me ayudó muchísimo
crwdns2935229:09crwdne2935229:0
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
This was so helpful, thank you! Also if you are in a jam and do not have a CR2016, you can use a CR2032 directly without using the normal battery tray.
Great help! Accurate, easy to follow directions
Excellent. Just what I needed, to bring life back to the dead.
the battery was stiff while getting it out, Make sure the battery orientation is correct
