CR-10S Pro Noctua Fan Upgrade
  1. CR-10S Pro Noctua Fan Upgrade, Included kit parts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Included kit parts: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Labeled bags are used in the following steps
    • Hardware
    • Power Supply Fan (Step 4)
    • Rear Case Exhaust Fan(Step 5)
    • Control Board Fan Assembly (Step 6)
  2. CR-10S Pro Noctua Fan Upgrade, Bottom cover and PSU mounting screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Bottom cover and PSU mounting screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Bottom cover and PSU mounting screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a #1 Phillips screwdriver, remove the 11 screws on the bottom and 2 screws on each side for a total of 15
    • Next, remove the bottom cover
    • With the bottom cover removed, turn the printer sideways and remove the power supple unit (PSU) screws while holding the PSU in place ribbon cable side up
  3. CR-10S Pro Noctua Fan Upgrade, Removing the PSU Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Removing the PSU Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Removing the PSU Fan: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 6 PSU screws securing the cover (circled in blue)
    • Next, remove the 2 screws securing the original 4020 Fan (circled in red)
  4. CR-10S Pro Noctua Fan Upgrade, Installing PSU Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Installing PSU Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Installing PSU Fan: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the original fan cable
    • Original fan cable is glued down. Gently, pull up on the cable to remove after you unplug the connector
    • Route the new fan cable under the white wires
    • Plug in new fan cable
    • Mount fan with Self tapping screws included in the kit
    • Pay attention to the fan orientation and wire placement
    • Follow step 2 in reverse for reinstallation of the PSU cover
  5. CR-10S Pro Noctua Fan Upgrade: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove M3 Screw holding stock fan and replace the fan with the new 4010 fan using the included M3x12 socket head screws
    • Fork connector for the red(+V) and black(-V) wire are mounted to there respect screw terminals on the PSU
  6. CR-10S Pro Noctua Fan Upgrade, Control Fan Assembly Installation: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Control Fan Assembly Installation: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CR-10S Pro Noctua Fan Upgrade, Control Fan Assembly Installation: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove original motherboard mounting screws and save for future step
    • Included Nylon standoffs replace control board mounting screws
    • Make sure SD card slot and USB cable slot maintain alignment with the frame cutouts
    • Place the Control Fan Assembly as shown
    • Use the previously remove M3 screws to secure the 3D printed fan mount to the standoffs.
    • Plug in Fan adapter cable
AJ Pereira
crwdns2935283:005/29/20crwdne2935283:0
2 707 crwdns2915208:0crwdne2915208:0
Tiny Machines 3D crwdns2935289:0Tiny Machines 3Dcrwdne2935289:0
Community
crwdns2935297:041crwdne2935297:0
crwdns2947412:08crwdne2947412:0
So where do you get the parts kit? I don’t see that in the post anywhere.
Tim Gray - crwdns2934203:0crwdne2934203:0
I would like to know where the parts kit can be purchased as well, either that or a list of part numbers.
lauriecrabb - crwdns2934203:0crwdne2934203:0
You can email us at support@tinymachines3d.com to order a kit
AJ Pereira -
Yes, it does apply to the CR10S Pro V2 as well
AJ Pereira -
How is the fan solved in step 5, the source is 24v and the fan is only 12v???
Tomáš Lašek - crwdns2934203:0crwdne2934203:0
A buck converter is used to step down the voltage to 12V
AJ Pereira -
Can this kit be used also for CR-X ? As they have mainly same components. THanks in advance.
Sancay Akbulut - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 107
crwdns2942667:0crwdne2942667:0 7,816
