The CHUWI GemiBook XPro may have overheating issues which may cause damage to the CPU and other components which could be caused by a defective fan. This step-by-step guide can be immediately followed after the Battery Replacement Guide regarding opening up this device. The tools required for this guide are the Spudger and a Philips 1 screwdriver. Please refer to our Fan Troubleshooting page for an extended list of symptoms and alternative solutions.
Orient the device to where you can see the bottom of the case.
Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
Insert an opening pick into the gap between the lower case and the chassis.
Pry along the entire perimeter of the laptop until the lower case fully releases.
Lift the lower case up and off of the chassis.
Peel off the black tape on the upper-right side of the motherboard.
Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
Lift the battery up and out of the chassis.
Use a spudger to push the fan connector out of its socket.
Carefully peel back the black tape on the radiator.
Use a Phillips #1 screwdriver to remove the two 4.2 mm screws that secure the fan.
Gently lift the fan out of the chassis, with care not to strain the connected wire.
Gently remove the fan cable from under other wires and fully remove the fan.
