This guide will show you the steps necessary for deconstruction and replacement of the CHI Original power cord.
Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
Remove the .53" long screw from the hinge pin.
This picture is out of order
You should only have to remove the back two screws and not any screws near the switch.
Separate the two halves of the CHI Original.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the spring pin with a pair of pliers or tweezers.
Remove the spring.
Remove (2) .31" Phillips head screws from back cover.
Remove cover.
Gently pull upwards on the connection point and disconnect the power cord.
What is part this person is holding in his right hand then clear part
crwdns2947412:05crwdne2947412:0
Do you know where to get a replacement power cord?
How/where do you purchase the replacement cord?
Where do you order an actual cord from??
Where we can get Power Cord?
Bonjour Nazim, j'ai trouvé le bon câble pour réparer le modèle GF1001EUN Farouk Systems USA sur le site web de pgservice :
Hi Nazim, I found the right cable to repair the GF1001EUN Farouk Systems USA model on the pgservice website :
Sonny -
Where do I find a new power cord?
ElenaStar* - crwdns2934203:0crwdne2934203:0
