Bose Soundlink Revolve Bottom Circuit Board Replacement
  1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve Bottom Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose Soundlink Revolve Bottom Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose Soundlink Revolve Bottom Circuit Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
    These are not the screws I have in my bose speaker. These are standard TORX screws ( with 6 sides) bose uses a special 5 sided secure torx screw(with a dot in the middle of the hole). A screwdriver or a screw-bit for these screws is very hard to find. I am still searching for one
    Frank - crwdns2934203:0crwdne2934203:0
    The 5 pointed Torx is also known as Torx Plus or an "IPR" bit, and you will have to get the security version with the hole. You are correct that they are hard to find. I searched several places locally but online was the only only way to go for me. ProTorq has an appropriate set available.
    Dave Freeman - crwdns2934203:0crwdne2934203:0
  3. Bose Soundlink Revolve Bottom Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Soundlink Revolve Bottom Circuit Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve Bottom Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Soundlink Revolve Bottom Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
    Where do you buy the usb/ aux port .
    kepac - crwdns2934203:0crwdne2934203:0
    I have a charging cradle and it still flashes red light not charging
    So maybe you have to work at Bose to get the part?
    John Halvorsen - crwdns2934203:0crwdne2934203:0
    I just wanted to find out if any android port can be connected and work or they are specific. Also when hot wiring the cables, is there a particular pattern or anything goes?
    Obbo Benjamin - crwdns2934203:0crwdne2934203:0
    How does one reattach the latch here exactly?
    andrewpalozzo - crwdns2934203:0crwdne2934203:0
    Bonjour, ces explications sont très claires mais il reste beaucoup à démonter et surtout on ne sait pas trouver la pièce défectueuse, sans parler d'en trouver une de rechange... Merci quand même mais le chemin est encore long pour réparer cet appareil...
    Henri - crwdns2934203:0crwdne2934203:0
    I suppose if you could open that thing, which might be hard (every smartphone today :D) to impossible without destructing the whole thing (eg Apple usb 3.0 camera adapter) - I haven’t tried it yet -, it’s an easy thing to desolder the ports and replace them with some from eBay or any other platform to buy stuff.
    Daniel Ullrich - crwdns2934203:0crwdne2934203:0
  6. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
    • Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
    • Remove the motherboard from the device.
Brian Butner
crwdns2935283:009/27/17crwdne2935283:0
897 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S6-G2, Remmell Fall 2017 crwdns2935289:0USF Tampa, Team S6-G2, Remmell Fall 2017crwdne2935289:0
USFT-REMMELL-F17S6G2
crwdns2947412:043crwdne2947412:0
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Gilberto - crwdns2934203:0crwdne2934203:0
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
romain thual -
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
seawolf1974 - crwdns2934203:0crwdne2934203:0
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Sullivan - crwdns2934203:0crwdne2934203:0
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Sam - crwdns2934203:0crwdne2934203:0
Hello Brain. I cannot find were to buy bottom circuit board for bose revolve. Could you sell it for me. mail: gonzser@gmail.com
Thank you
Gonzalo
Gonzalo de la Serna - crwdns2934203:0crwdne2934203:0
Hey Brian I also need the circuit board for the nose revolve and the battery. If you can help me. Thanks my email is lambertjsmith@gmail.com
Jesse - crwdns2934203:0crwdne2934203:0
Hello Brain. I cannot find were to buy bottom circuit board for bose revolve. Could you sell it for me. mail: Rick bull566@aol.com
Thank you
bull566 - crwdns2934203:0crwdne2934203:0
Hi. your guide is great and just what i needed. can you tell me where to purchase a usb port and lower circuit board? thx.
heres my email: andrew.demchuk@yahoo.com
Andrew G Demchuk - crwdns2934203:0crwdne2934203:0
Hi Brain, I also need to replace bottom circuit board for Bose revolve. Can you tell me where to buy it? My mail: bjspeek@live.nl
bjspeek - crwdns2934203:0crwdne2934203:0
Just broke the ribbon connector when taking this thing apart. Do you know where I am able to get a replacement bottom circuit board Brian?
hamishwoyka@gmail.com
hamishwoyka - crwdns2934203:0crwdne2934203:0
Where can I find the bottom circuit board ? Jlorusso24@gmail.com. Thank you!
Jimbo James - crwdns2934203:0crwdne2934203:0
Hello, I too need to buy a new bottom circuit board for the Bose SoundLink Revolve. jaburge1@gmail.com. Thank you!
FunGeorge - crwdns2934203:0crwdne2934203:0
Hi I require the bottom circuit board are you able to provide this item for sale. david_lee24@hotmail.co.uk
David Holmes - crwdns2934203:0crwdne2934203:0
Need to buy board and cable, please. reimao@gmail.com
Pedro Reimao - crwdns2934203:0crwdne2934203:0
Hello Brain.
Could you sell it for me?
mail: fabforrun@gmail.com
Thank you
Fabien
Fabien Clementz - crwdns2934203:0crwdne2934203:0
Hey thank you for the help but where can i buy the bottom circuit board. pls?
My contact slwebuse@gmail.com
regards,
scott
scott - crwdns2934203:0crwdne2934203:0
Hello, do you sell the bottom circuit board for bose? , could you sale it for me: mail: sa_alexandre@hotmail.com, delivery to Brazil. Best regards
sa_alexandre - crwdns2934203:0crwdne2934203:0
Hello i need the bottom circuit board for the revolve Bose
do you sell it ? Or can you tell me where can I get it ? guillermo_alc@hotmail.com
birdcacatua - crwdns2934203:0crwdne2934203:0
Hello, I would also need the circuit replacement board. My email is Jolilum1@gmail.com
Thanks a lot,
Juan.
Jolilum1 - crwdns2934203:0crwdne2934203:0
bottom circuit board link ? I need one as well
Alan.cyr(AT)gmail(dot)com
Alan Cyr - crwdns2934203:0crwdne2934203:0
Hello, I am also looking for the bottom circuit board for Bose Revolve. Thanks, regards, efreibox@hotmail.com
jean - crwdns2934203:0crwdne2934203:0
Hello, as anyone know where we can find the bottom circuit board. Thank you, efreibox@hotmail.com
kkc6143@gmail.com
kkc6143 - crwdns2934203:0crwdne2934203:0
I am also looking for the bottom circuit board for Bose Revolve. michael@parsche.net
Michael Parsche - crwdns2934203:0crwdne2934203:0
Anyone found where to buy this circuit board?
fmpitschieller - crwdns2934203:0crwdne2934203:0
hello, I’m also looking for the sparepart.Did you get any news regarding where to buy it?
Thanks in advance
marcos tito Elizalde -
hello i have broken the tablecloth on the board where to find it ???
u2forevernow - crwdns2934203:0crwdne2934203:0
Hello, nice tutorial, how to get the item? Can you send one to France? Veens876@gmail.com
veens876 - crwdns2934203:0crwdne2934203:0
Need the bottom circuit board where can i buy it .
Humberto nieves - crwdns2934203:0crwdne2934203:0
Hello, I’d also would like to buy a bottom circuit for bose revolve. Do you know where I could find it ?
Thank you for helping and for your site.
Romain
cornazro@gmail.com
romain cornaz - crwdns2934203:0crwdne2934203:0
Hi Friends,
I got a supplier for original power circuit board but price is not cheap. Is there any that we can direct purchase from Bose?
joytech asia - crwdns2934203:0crwdne2934203:0
Hi thanks for this tutorial, i need the circuit board  for this bose revolve. Do you sell it ?
my mail : gregory@adelios.fr
Thx
G.C
gregory - crwdns2934203:0crwdne2934203:0
Hello, where you able to purchase this from a website? regards Gareth
gareth mccombe -
is there a website where i can buy the circuit?
UsuelTundra1994 - crwdns2934203:0crwdne2934203:0
Hello do you sale replace my parts?
gareth mccombe - crwdns2934203:0crwdne2934203:0
Where can one purchase this circuit board? Haven't been able to locate one anywhere.
David Morrison - crwdns2934203:0crwdne2934203:0
wo und wie kann ich den ganzen Platine kaufen
Hamed Nik - crwdns2934203:0crwdne2934203:0
i need the bottom board, can i know the cost
Lakshmanan Annamalai - crwdns2934203:0crwdne2934203:0
Hey there, I also require the bottom circuit board for my Bose Revolve at India, lakshmanan1413@gmail.com
Looking for a usb charging port for a bose revolve bluetooth speaker.
Kenworth Charles - crwdns2934203:0crwdne2934203:0
Is it possible to add a high resolution closeup of both sides of the PCB please? I have one for repair, and it is missing components, but I am unable to find out the ratings of the missing components.
Kristian Roberts - crwdns2934203:0crwdne2934203:0
Hi, i'll try my luck but is the ribbon mentionned in step 6 available somewhere ?
gainon.cyril@hotmail.fr in austria
R D (RaizenCorp) - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 15,557
