If you are experiencing problems with your Soundlink III's functioning such that the device won't turn on or certain buttons won't work, your motherboard may need replacement.
Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
Remove the bottom panel.
easy peasy. great instructions!
couple things: 1. you dont need to remove the rubber pads completely; just enough to get the screws in & out. 2. if you get a small screw driver with the battery, its crap. use your own.
thank you ifixit for another great tutorial.
scott
My SL III battery lasted nearly 8 years with almost daily use—but recently stopped holding a charge for more than 15-20 minutes. Replacement was super easy so thanks for posting. Bose quality is exceptional as always!
Flip the rear panel back to allow access to the SoundLink's battery.
Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
Super Erklärt!!
You do not have to remove the rubber completely. Just lift up the ends towards the middle to reveal the screws.
Gently peel back the adhesive padding on either side of the inner back panel.
Remove the four 12.5 mm Phillips #2 screws mounting the outer case.
Slide off the outer case.
Remove four screws from each of the four speakers (16 screws total) using a Torx #10 screwdriver.
Remove the two 12.5 mm screws which mount the top panel using a Phillips #2 screwdriver.
Now you should be able to lift the top panel off.
Use a metal spudger to pry the device apart. You must use a metal spudger because of the great force necessary to pry it apart.
Remove the 12.5 mm screw mounting the motherboard using a Philips #2 screwdriver.
Gently disconnect the three cables connected to the motherboard.
Remove the motherboard from the device.
Hi, I have to replace my SLIII motherboard.
The question is. Where can I get one ?
