Bose Soundlink III Battery Replacement
  1. Bose Soundlink III Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose Soundlink III Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Soundlink III Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
    easy peasy. great instructions!
    couple things: 1. you dont need to remove the rubber pads completely; just enough to get the screws in & out. 2. if you get a small screw driver with the battery, its crap. use your own.
    thank you ifixit for another great tutorial.
    scott
    Scott Oakley - crwdns2934203:0crwdne2934203:0
    My SL III battery lasted nearly 8 years with almost daily use—but recently stopped holding a charge for more than 15-20 minutes. Replacement was super easy so thanks for posting. Bose quality is exceptional as always!
    hoya - crwdns2934203:0crwdne2934203:0
  3. Bose Soundlink III Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose Soundlink III Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Soundlink III Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
    You do not have to remove the rubber completely. Just lift up the ends towards the middle to reveal the screws.
    bart - crwdns2934203:0crwdne2934203:0
crwdns2935229:039crwdne2935229:0
Dakoda Sanders
crwdns2935283:002/04/16crwdne2935283:0
1,558 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-2, Wollert Spring 2016 crwdns2935289:0USF Tampa, Team 3-2, Wollert Spring 2016crwdne2935289:0
USFT-WOLLERT-S16S3G2
crwdns2947412:027crwdne2947412:0
Hello, I wonder where I could buy a raplacement battery for my Bose Soundlink III. (I'm from Belgium)
Thanks for the response.
Gabriel Lohest - crwdns2934203:0crwdne2934203:0
Gabriel, ik heb Bose gecontacteerd en ze zeggen dat ze dat niet apart verkopen. Het enigste wat ik heb gevonden is dit:http://www.ecrater.com/p/25268626/batter...
Of als het nog onder garantie valt, gewoon terug opsturen.
Gabrial, I've contacted Bose and they say that they didn't sell them seperately. The only thing that I've found is this:http://www.ecrater.com/p/25268626/batter...
If it still falls under warranty, send the speaker back.
JJ Hu - crwdns2934203:0crwdne2934203:0
yea i'm also interested to buy bose soundlink 3 battery hurmmm where could i get it....
Admin Fluffy - crwdns2934203:0crwdne2934203:0
Yes please, where do you get replacement batteries (I'm from Australia and Bose here want to charge me $149 to remove and replace 4 screws!)
Bob Mandassa - crwdns2934203:0crwdne2934203:0
I want to buy also. I'm here in Saudi arabia dammam
alphamendoza5 - crwdns2934203:0crwdne2934203:0
I’m from Nigeria where can I get a replacement battery for my Bose III
Raymond Richard -
My bose SL3 just stopped working so I thought maybe a charge...nothing ..charge indicator just pulses yellow and doesn't do anything no other lights will turn on anytime and won't charge or play ..was fine till instantly..done
Robert Johnson - crwdns2934203:0crwdne2934203:0
What batteries are needed for Bose Bluetooth Soundlink 3
Norman - crwdns2934203:0crwdne2934203:0
What batteries are needed to replace Bose Bluetooth Soundlink 3
Hi everyone, is there anybody find a store to buy battery for Bose Bluetooth Soundlink III. Please help..
floreswb - crwdns2934203:0crwdne2934203:0
I purchase a replacement battery for your bose Soundlink 3 from Amazon.It work well.You could purchase it on Amazon.
Link: https://www.amazon.com/gp/product/B077G8...
Emily - crwdns2934203:0crwdne2934203:0
im from the uk is there anywhere in England I can buy a battery for the bose soundlink 3 please
tonybowman9163 - crwdns2934203:0crwdne2934203:0
just contact sales@sfelectronics.biz they have them for 20 bucks
Robert Wisniewski - crwdns2934203:0crwdne2934203:0
I’ve changed the battery (easy) but now battery indicator light keeps flashing red ? What’s going on
karenbudden1968 - crwdns2934203:0crwdne2934203:0
Here is a link to new batteri for your soundlink 3 3 years warranty and good price as well
https://www.subtel.se/Batteri-f-r-Bose-S...
Rolf Carlsson - crwdns2934203:0crwdne2934203:0
I'm from fiji, battery indicator keeps flashing red,what does that mean
niumaia lawanicina - crwdns2934203:0crwdne2934203:0
Bought the replacement battery on Amazon. Used this video guide to replace. Went without a hitch. Thanks Dakoda.
Paul Zuhoski - crwdns2934203:0crwdne2934203:0
:( Sorry only now I saw your answer
Ed Oliver -
the battery assembly is just 3x 1850 cells or similar problem is they are chipped. so no good will from Bose. you could try to transfer the chip to 3 new cells .
Todd - crwdns2934203:0crwdne2934203:0
Thank you for a straightforward and comprehensive guide. My first time at this and it was as easy as changing a regular torch battery, only with an extra screw or two.
Joan Hammond - crwdns2934203:0crwdne2934203:0
Thanks, Dakota! I followed your instructions and found them to be accurate and complete. I thank you for them. There are various sellers on Ebay for these replacement batteries.
Del Tucker - crwdns2934203:0crwdne2934203:0
Perfect instructions!! Thanks!!
Angela Martin - crwdns2934203:0crwdne2934203:0
Need to work on adapter because battery is too expensive kindly guide or give data of that 5 pin 1&5 is 11.2 2&3 sda&sdc can we by pass by erasing eeprom data 9323011568 Mumbai
paulfun11 - crwdns2934203:0crwdne2934203:0
I need to buy this battery in India
Javed Masood - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 103
crwdns2936753:030crwdne2936753:0 459
crwdns2942667:0crwdne2942667:0 63,402
