Bose SoundTouch 10 Back panel Replacement
  1. Bose SoundTouch 10 Back panel Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the speaker over so that the rubber strips along the bottom are facing you.
    • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
  2. Bose SoundTouch 10 Back panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
  3. Bose SoundTouch 10 Back panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundTouch 10 Back panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
    • Lift the panel away to reveal the speaker head.
    It’s on tight, need to push downwards fairly hard.
    John Olsen - crwdns2934203:0crwdne2934203:0
  4. Bose SoundTouch 10 Back panel Replacement, Back panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
  5. Bose SoundTouch 10 Back panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the speaker onto its back.
    • Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
  6. Bose SoundTouch 10 Back panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundTouch 10 Back panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
    • If the panel does not come free easily, a heat gun may be needed to weaken the adhesive.
    • Once the panel has been disconnected, it should fall open revealing the motherboard.
  7. Bose SoundTouch 10 Back panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundTouch 10 Back panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
    What is the serial number or spare part number of that ribbon.
    STIVEN RAMIREZ - crwdns2934203:0crwdne2934203:0
  8. Bose SoundTouch 10 Back panel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundTouch 10 Back panel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motherboard contains capacitors (shown as cylinders in the upper right of the picture) which can hold a charge even when the speaker is powered off. Do not touch them as doing so may result in a shock.
    • Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
    Only the upper part takes off (the one that is whiter). The other part coresponds to the base, and it is unremovable
    Andrés Tumini - crwdns2934203:0crwdne2934203:0
    To remove the plug, squeeze the very top of the plug to unlatch the plug, then pull on the plug to remove it.
    Where can I buy parts at?
    Mark - crwdns2934203:0crwdne2934203:0
James Asbury
crwdns2935283:004/10/17crwdne2935283:0
898 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S13-G1, Forte Spring 2017 crwdns2935289:0Cal Poly, Team S13-G1, Forte Spring 2017crwdne2935289:0
CPSU-FORTE-S17S13G1
How can I install a 12v battery?
Quique - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 7,101
