Use this guide to replace the front or back mesh grilles. Make sure you have the required tools. The first time you remove a grille might be a little difficult due to some glue holding it in place. Be careful when removing, as the grille may bend easily.
Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
Slowly pry up the grille until the two tabs shown pop out.
The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
Repeat steps to remove the back grille.
Attention à la longueur des vis (les 4 vis du côté du circuit sont les 4 plus longue) et si vous vous trompez et plaçez ces 4 vis ailleurs vous risquez de les briser et que le bout de celles-ci demeurera dans la partie du chassis.
crwdns2935229:010crwdne2935229:0
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Steps are wrong and difficult. Try taking out from somewhere between the center, it will automatically pull the locks out which are located on the sides.
Woher bekomme ich nun rin solches Vorder- und Rückgitter?
[COBS]CR4ZY BLITZ - crwdns2934203:0crwdne2934203:0
