Use this guide to replace the front or back mesh grilles. Make sure you have the required tools. The first time you remove a grille might be a little difficult due to some glue holding it in place. Be careful when removing, as the grille may bend easily.
Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
Slowly pry up the grille until the two tabs shown pop out.
The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
Repeat steps to remove the back grille.
crwdns2935229:010crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
