BolaButty X-GO C27-C Motherboard Replacement
  1. BolaButty X-GO C27-C Motherboard Replacement, Charging Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement, Charging Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement, Charging Port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take an opening tool or pick and wedge it into the groove between the endcap and the main casing. Wiggle it back and forth.
    • Strike the speaker endcap firmly against a solid surface to pop the end caps off.
    • Removing the end caps requires a good amount of force. There is a realistic chance that you will damage your speaker or break the caps.
  2. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge an opening tool or a pick under the speaker cover and work it back and forth to loosen it. Repeat for all four sides.
    • Remove the speaker cover.
  3. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 12 mm screws securing the driver housing using a Phillips #0 screwdriver.
    • Gently pull apart the two halves of the speaker.
    • Take care not to strain the cables.
  4. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three 10 mm screws securing the charging housing.
    • Separate the charging port from the battery.
  5. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to lift the black ZIF locking flap securing the ribbon attached to the charging port.
    • While pulling up on the latch, remove the ribbon.
  6. BolaButty X-GO C27-C Motherboard Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery connector from its motherboard port.
  7. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift the battery from the casing.
    • The battery is secured with some adhesive. If you have a difficult time removing it, use a hairdryer to lightly heat the adhesive.
  8. BolaButty X-GO C27-C Motherboard Replacement, Drivers: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement, Drivers: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the LED board.
    • There will be some adhesive securing the board in place, so it won't feel like it will come out easily. Wiggle the board back and forth to loosen it before pulling vertically to remove.
  9. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the driver connectors from the motherboard.
    • Remove the driver.
    • If you have difficulty with the wires, wiggle the connector back and forth to loosen it.
  10. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat previous two steps for the second speaker.
  11. BolaButty X-GO C27-C Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to disconnect the two cables connected from the daughterboard.
    • Make sure to pull on the plastic connector and not on the wires to avoid damaging the wires.
  12. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the four 8 mm screws holding the motherboard in place.
  13. BolaButty X-GO C27-C Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Young
crwdns2935283:003/27/25crwdne2935283:0
203 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-5, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 3-5, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S3G5
crwdns2942667:0crwdne2942667:0 61
