BolaButty X-GO C27-C Charging Port Replacement
  1. BolaButty X-GO C27-C Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BolaButty X-GO C27-C Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BolaButty X-GO C27-C Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take an opening tool or pick and wedge it into the groove between the endcap and the main casing. Wiggle it back and forth.
    • Strike the speaker endcap firmly against a solid surface to pop the end caps off.
    • Removing the end caps requires a good amount of force. There is a realistic chance that you will damage your speaker or break the caps.
  2. BolaButty X-GO C27-C Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge an opening tool or a pick under the speaker cover and work it back and forth to loosen it. Repeat for all four sides.
    • Remove the speaker cover.
  3. BolaButty X-GO C27-C Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 12 mm screws securing the driver housing using a Phillips #0 screwdriver.
    • Gently pull apart the two halves of the speaker.
    • Take care not to strain the cables.
  4. BolaButty X-GO C27-C Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three 10 mm screws securing the charging housing.
    • Separate the charging port from the battery.
  5. BolaButty X-GO C27-C Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BolaButty X-GO C27-C Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to lift the black ZIF locking flap securing the ribbon attached to the charging port.
    • While pulling up on the latch, remove the ribbon.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
jcate
crwdns2935283:003/21/25crwdne2935283:0
497 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-5, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 3-5, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S3G5
crwdns2942667:0crwdne2942667:0 188
