The lithium-ion battery used in the BolaButty X-GO speaker will wear from use over time, and will eventually lose its ability to store and deliver power efficiently, in which case a replacement is necessary.
Before replacing the battery make sure your charger isn't the issue. Try using a different charger to confirm that the battery won't hold a charge. Also be sure to check the charging port to make sure it isn't having issues connecting to the charger. The battery will be the most likely issue, but it is still a good idea to make sure nothing is bent, warped, or out of place.
The battery might appear swollen if it has been compromised, in which case you should replace it as soon as you can.
If you are replacing and other components, it's a good idea to remove the battery before accessing them for safety reasons. Once you open the device, you will also discover that the device separates into two halves, with the wire from the battery connecting the two. Removing or at least separating the battery's connection will make accessing the motherboard and other components easier.
The battery is secured underneath the charging port, so you will have to remove that first.
Take an opening tool or pick and wedge it into the groove between the endcap and the main casing. Wiggle it back and forth.
Strike the speaker endcap firmly against a solid surface to pop the end caps off.
Wedge an opening tool or a pick under the speaker cover and work it back and forth to loosen it. Repeat for all four sides.
Remove the speaker cover.
Remove the eight 12 mm screws securing the driver housing using a Phillips #0 screwdriver.
Gently pull apart the two halves of the speaker.
Use a Phillips #0 screwdriver to remove the three 10 mm screws securing the charging housing.
Separate the charging port from the battery.
Use a pair of tweezers to lift the black ZIF locking flap securing the ribbon attached to the charging port.
While pulling up on the latch, remove the ribbon.
Disconnect the battery connector from its motherboard port.
Use a spudger to lift the battery from the casing.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
