Board Shield Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Board Shield Removal, Uncover the back panel screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal, Uncover the back panel screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
  2. Board Shield Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  3. Board Shield Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
  4. Board Shield Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  5. Board Shield Removal, Remove the back panel screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal, Remove the back panel screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $17.96
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
  6. Board Shield Removal, Unclip the back panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Unclip the back panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Unclip the back panel: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  7. Board Shield Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  8. Board Shield Removal, Remove the back panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Remove the back panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Remove the back panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  9. Board Shield Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  10. Board Shield Removal, Remove the fan screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal, Remove the fan screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.3 mm‑long pancake screw
    • Two 9 mm‑long screws
  11. Board Shield Removal, Disconnect the fan cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Disconnect the fan cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Disconnect the fan cable: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
    • Grip your tweezers close the connector to get a better grip.
    • Pull the connector straight out of the socket to disconnect it.
    • If you're having trouble, gently rock the connector side to side to loosen it.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  12. Board Shield Removal, Remove the fan: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Remove the fan: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Remove the fan: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Dust Blower
    $18.99
    • Slide the fan out of its slot to remove it.
    • During reassembly:
    • Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • Note that the fan can only be installed one way—make sure Master Chief is facing you.
  13. Board Shield Removal, Unlatch the base: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Unlatch the base: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Unlatch the base: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
    • Keep the locking tab held open for the next step.
  14. Board Shield Removal, Twist and remove the base: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Twist and remove the base: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Twist and remove the base: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
  15. Board Shield Removal, Disconnect the USB port cable: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Disconnect the USB port cable: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Disconnect the USB port cable: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  16. Board Shield Removal, Heat the USB port cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Heat the USB port cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Heat the USB port cable: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The USB port cable is secured to the chassis with two pieces of mild adhesive.
    • Use an iOpener or a hair dryer to heat the USB port cable.
  17. Board Shield Removal, Detach the USB port cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Detach the USB port cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Detach the USB port cable: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $2.99
    • Slide an opening pick under the USB port cable to separate the adhesive securing it.
    • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
  18. Board Shield Removal: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to gently pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • Move the USB port cable out of the way of the chassis.
  19. Board Shield Removal, Disconnect the power button cable: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Disconnect the power button cable: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Disconnect the power button cable: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Board Shield Removal, Remove the chassis screws: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal, Remove the chassis screws: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove the three 7.4 mm‑long green screws securing the center chassis assembly to the shell.
  21. Board Shield Removal, Remove the chassis: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Remove the chassis: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Remove the chassis: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The center chassis assembly is aligned to the bottom of the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
    • Use two hands to lift out the chassis to remove it from the shell.
    • Make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
    • Use the alignment pegs and cutouts to properly orient the chassis in the shell:
    • Two pegs on the chassis with cutouts on the bottom of the shell.
    • Three pegs in the shell with cutouts on the chassis.
  22. Board Shield Removal: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Dust Blower
    • Gently place the chassis heatsink-side down on a clean work surface.
    • During reassembly, this is a good point to clean the heatsink fins of any dust, dirt, or debris that may have built up over time. Use a dust blower or compressed air to clear out the fins.
  23. Board Shield Removal, Remove the antenna board screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal, Remove the antenna board screws: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
  24. Board Shield Removal, Remove the accessory antenna board: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Remove the accessory antenna board: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal, Remove the accessory antenna board: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  25. Board Shield Removal, Remove the power cable port: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal, Remove the power cable port: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm‑long screws
    • One 35 mm‑long screw
  26. Board Shield Removal: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the power connector out of its recess in the chassis.
  27. Board Shield Removal, De-route the power cables: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal, De-route the power cables: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Board Shield Removal: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Board Shield Removal, Remove the board shield: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Board Shield Removal, Remove the board shield: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove the ten screws securing the board shield:
    • Seven 8.7 mm‑long screws
    • Two 35 mm‑long screws
    • These screws are very tight and may take significant force to loosen.
    • One 13 mm‑long screw
  30. Board Shield Removal: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Board Shield Removal: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the power supply cable out of the way and lift the board shield straight up to remove it.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
118,756 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,614crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 41
