Blu Dash 5.0 Dual SIM Battery Replacement
  1. Blu Dash 5.0 Dual SIM Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
    If slot 1 is messed up can you use slot 2 for simcard and the phone still work
    Margie White - crwdns2934203:0crwdne2934203:0
  2. Blu Dash 5.0 Dual SIM Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
crwdns2935229:05crwdne2935229:0
Dashaya Toney
crwdns2935283:010/27/14crwdne2935283:0
876 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-7, Miles Fall 2014 crwdns2935289:0UMass Dartmouth, Team 4-7, Miles Fall 2014crwdne2935289:0
UMASSD-MILES-F14S4G7
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 4,125
