Blink Video Doorbell Lens Replacement
  1. Blink Video Doorbell Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Lens Replacement, Back Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement, Back Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement, Back Panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Lens Replacement, Lens: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement, Lens: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blink Video Doorbell Lens Replacement, Lens: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blink Video Doorbell Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift up the small daughterboard which contains the camera.
    • Remove two 5 mm screws from the back of the camera using a Phillips #0 screwdriver.
  7. Blink Video Doorbell Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blink Video Doorbell Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the lens.
Kayla Crai
crwdns2935283:010/18/24crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-1, Konn Fall 2024 crwdns2935289:0UMass Dartmouth, Team 1-1, Konn Fall 2024crwdne2935289:0
UMASSD-KONN-F24S1G1
Is it available to purchase the lens
William - crwdns2934203:0crwdne2934203:0
Where can the replacement module/adapter be purchased?
William Meade - crwdns2934203:0crwdne2934203:0
Where can we get the right replacement?
Very helpful article otherwise!
Jesse Jewell - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 203
crwdns2942667:0crwdne2942667:0 766
