Remove the four T5 screws.
Remove the single T5 screw from the bottom, next to the charging port.
Remove the screws from the sides.
Remove the screws holding the camera frame.
Press the chamfered left or right extremities of the frame (between the screws) to rock the frame loose. The opposite side will pop-up, to lift off easily.
Pry out the sim car holder
Use a spudger or a utility knife to pry off the side bezels.
Pry in one corner and separate the back.
Use a plastic spudger to disconnect the flex connectors.
Use a plastic spudger to disconnect the flex connector and the antenna
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Heat up this PCB with either iOpener or a heat gun on low temp (100-120 Celsius) to loosen the adhesive and pry it off from the side.
Remove the screws.
The last screw is under a tamper-proof sticker
Use plastic spudger or tweezers to disconnect the camera flex cable from the top
Disconnect the flex cable
Disconnect the antenna
Remove the screws from the battery cover
Disconnect the flex connectors and remove the battery
Remove two J000 screws
Carefully pry up the camera. Heat from the glass side if necessary.
Unscrew and remove the camera assembly
Heat the light sensor from both sides to loosen the adhesive and gently pry them out of their sockets
Use some isopropyl alcohol if necessary to loosen the glue further on the audio jack
Grab it with strong tweezers and wiggle from side to side and upwards until it comes out. Heat further if necessary.
Lift it out and transfer to the new screen.
Gently peel the flex cable u p and transfer to the new assembly.
Heat up and pry up the bottom PCB (charging port) and transfer to the new screen.
You saved my mobile phone. Even I did not replace the screen, I just replace the battery. I forgot some connectors but your post remind me and the mobile back to work!
I’m glad that you managed to save your device!
Might want to add importance of magnetic something to keep screws organized. Amazing how many people don't pay attention to the concept of putting screws back into same hole they came out of
Shelly J Webb - crwdns2934203:0crwdne2934203:0
