Blackberry PRIV Rear-Facing Camera Replacement
  1. Blackberry PRIV Rear-Facing Camera Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Look for the two small holes at the top of your device.
    • Use a SIM eject tool to push down into the holes which lifts the SIM and SD trays.
    • Pull the trays up and out of the device.
  2. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the seam between the rear casing and chassis. Apply downward pressure to pry the casing upward.
    • Follow this procedure for only the right, left, and top side of the casing.
  3. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rear casing by sliding the case down and out.
  4. Blackberry PRIV Rear-Facing Camera Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.3 mm T4 Torx screws that secure the battery connector.
    • There may be a plastic protector covering the circuit board and battery. Remove the plastic protector to begin.
  5. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to lift and disconnect the battery connector.
  6. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull on the plastic tab to remove the battery from the device.
    • For easier removal, use a blow dryer to warm the battery glue.
    • Be careful to not overheat the battery or puncture the battery as lithium batteries are dangerous.
  7. Blackberry PRIV Rear-Facing Camera Replacement, Rear-Facing Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 3.3 mm T4 Torx screws that secure the motherboard.
  8. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3.3 mm T4 Torx screws that secure the speaker casing.
    • Lift and remove the speaker casing.
  9. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the one 3.3 mm T4 Torx screw that secures the headphone jack.
    • Lift and remove the headphone jack.
  10. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to lift and disconnect the three press connectors.
  11. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard from the device.
    • Do not pull the circuit board with too much force as there is a strip connected under.
    • Using two fingers, pinch the on the strip as close to the connector as possible.
    • Lift and disconnect the connector from the motherboard.
  12. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the motherboard around.
    • Use an opening tool to lift and disconnect the camera connector.
  13. Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Blackberry PRIV Rear-Facing Camera Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the camera from the circuit board.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Benjamin Olvera
crwdns2935283:009/25/24crwdne2935283:0
563 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-4, Sneed Fall 2024 crwdns2935289:0University of Memphis, Team 1-4, Sneed Fall 2024crwdne2935289:0
UM-SNEED-F24S1G4
crwdns2942667:0crwdne2942667:0 77
