Use this guide to replace the damaged rear casing on your BlackBerry Priv phone. The rear casing protects internal hardware from physical damage. A cracked casing can expose sensitive parts to dust, moisture, and impacts, affecting performance and potentially damaging buttons or ports if left unchecked. In step 2 of this guide, if you don’t have a SIM eject tool, you can use the end of a paperclip which is just as effective.
Look for the two small holes at the top of your device.
Use a SIM eject tool to push down into the holes which lifts the SIM and SD trays.
Pull the trays up and out of the device.
Insert an opening pick in the seam between the rear casing and chassis. Apply downward pressure to pry the casing upward.
Remove the rear casing by sliding the case down and out.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
