BlackMagic Hyperdeck Studio Mini Fan Replacement
Kevin Krautle
crwdns2944107:0crwdnd2944107:0Kevin Krautlecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Ndz 28, 2024crwdne2944111:0
crwdns2931287:030crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
BlackMagic Hyperdeck Studio Mini has a very loud fan that can be replaced to make the quieter.
WARNING - THIS WILL VOID YOUR WARRANTY!
crwdns2944105:0crwdne2944105:0
crwdns2936621:0crwdne2936621:0
  1. BlackMagic Hyperdeck Studio Mini Fan Replacement, Unscrew the Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 4 Screws on each side
  2. BlackMagic Hyperdeck Studio Mini Fan Replacement, Remove Fan: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2 - Screws
    • 1 - Pull cable
  3. BlackMagic Hyperdeck Studio Mini Fan Replacement, Cut Off Connector from both the old and new fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Leave some length to solder with and to reach connector on main board.
  4. BlackMagic Hyperdeck Studio Mini Fan Replacement, Prep Fan Wires and Connector Wires: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Strip Wires, Tin Wires, and prep by adding heat shrink tubing on wires (before shrinking).
  5. BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Solder the new fan to the old connector using the following pinout.
    • Adjust heat shrink tubing so it covers the solder joints and use heat gun to shrink tubing.
  6. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-assemble fan to device with fan label facing out: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-assemble fan to device with fan label facing out: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Re-assemble fan to device with fan label facing out.
    • OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter.
  7. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-Assemble Case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Re-Assemble case.
Kevin Krautle
crwdns2935283:010/10/16crwdne2935283:0
562 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
THANK YOU SO MUCH!!!! This was the perfect solution. The new Noctua fan even came with solderless connectors. The whole job only took 20 minutes. It is now completely silent!
tberntson - crwdns2934203:0crwdne2934203:0
Just replaced mine monitoring the temperature now. As @tberntson mentioned, the fan comes with some Skotchlok connectors and no soldering even required. I can’t believe how quiet the new fan is. Complete night and day difference. Kevin, thanks so much for sharing this.
Adrian Cho - crwdns2934203:0crwdne2934203:0
Hi! any one that have the part number for the Nactua fan with Skotchlok connectors is it NF-A4x20-PWM?
mikaelf - crwdns2934203:0crwdne2934203:0
The connector you need is a Micro JST ZH 1.5mm 4-pin female connector. You can pick them up pre-wired on eBay.
Jamie - crwdns2934203:0crwdne2934203:0
Thank you so much! I soldered it and it works great! So silent now that I can´t hear it at all!
pzacharias - crwdns2934203:0crwdne2934203:0
Nice! Looks like the older Ultrastudio 4K Thunderbolt2 unit uses the JST ZH 3-pin connectors too. (The ZH family is 1.5mm spacing.) I think I'll try a Noctua NF-A4x10 there.
Drew - crwdns2934203:0crwdne2934203:0
Hi!
I know it’s not related to that but do you have any idea of where I can find a power board replacement for this Hyperdeck model?
Thx!
Filippo M - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 4,889
