If the buttons on your BlackBerry Tour 9630 are unresponsive or become difficult to push, then your keypad is probably damaged or dirty. Use these step-by-step instructions to replace your BlackBerry Tour 9630 keypad and get it working like new again!
Position the phone so that the keyboard is facing down and the back is facing up.
Push the center silver button upwards to release the back cover.
Take the back cover off and set it to the side.
Grip the battery where the light grey half circles are located and pull up.
Set the removed battery to the side with the back cover.
If there is an SD card, press gently on the card and slide it up to remove.
If there is a SIM card, press gently on the card and slide it left to remove.
Use the T6 Torx screwdriver to remove the four 8.00 mm screws from the back of the phone.
Use an opening tool to pry the top plastic cover off.
Use the T6 Torx screwdriver to remove the two 8.00 mm screws from the top of the phone.
Use a spudger to release the clips connecting the front and back case.
Separate the front and back of the device.
Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect it.
Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the black and white coaxial connectors (as close to the head as possible) and lift straight up from the board.
Gently push up on the keyboard from below to remove the front cover frame.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
