BlackBerry KEYone Motherboard Disassembly
  1. BlackBerry KEYone Motherboard Disassembly, The BlackBerry KEYone: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The start of our disassembly. The BlackBerry KEYone logo screen.
  2. BlackBerry KEYone Motherboard Disassembly, Remove the Sim Card Tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a sim card removal tool to remove the sim card.
  3. BlackBerry KEYone Motherboard Disassembly, Heat the top of the phone: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply heat to the top of the phone to remove the microphone plastic cover. There is a fair amount of adhesive holding this cover down.
  4. BlackBerry KEYone Motherboard Disassembly, Remove the Plastic Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an iSesamo or other preferred pry tool to remove the plastic cover from the BlackBerry.
  5. BlackBerry KEYone Motherboard Disassembly, Remove two Phillips screws.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips screws. They may be hiding under some adhesive.
  6. BlackBerry KEYone Motherboard Disassembly, Slide off the Plastic Top of the Phone: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The plastic top of the phone will slide off after removing the two screws.
  7. BlackBerry KEYone Motherboard Disassembly, Remove the Rear Plastic Battery Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the top plastic cover off it is pretty easy to use your preferred plastic pry tool and remove the battery cover.
  8. BlackBerry KEYone Motherboard Disassembly, Remove the Loud Speaker Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the back cover is off remove the 7 Phillips Screws at the bottom of the phone that are covering the loudspeaker and the part of the motheboard where the USB type-C charging port is located.
  9. BlackBerry KEYone Motherboard Disassembly, Remove the Metal Flex Connector Bracket: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removing the loud speaker cover will allow you to remove the other two Phillips screws for the metal bracket that covers up a couple flex connectors.
  10. BlackBerry KEYone Motherboard Disassembly, Disconnect the Battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two Phillips screws connecting the battery flex connector to the motherboard. Now you can remove the battery. There is ALOT of adhesive holding the battery in place. I recommend applying heat and using a plastic tool to slowly work the battery out. The volume and power flex runs under the battery. Be cautious near the top left.
  11. BlackBerry KEYone Motherboard Disassembly, Disconnect the Flex Cables: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the battery out disconnect the three flex cables and remove the remaining two Phillips screws from this area of the motherboard.
  12. BlackBerry KEYone Motherboard Disassembly, Remove the Black Plastic Bracket: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are three Phillips screws holding down a black plastic bracket that was previously partially covered by the silver bracket removed earlier. Two of the screws are visible without removing the silver top bracket but the third middle screws requires the top bracket be removed first.
  13. BlackBerry KEYone Motherboard Disassembly, Remove the Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With all screws and brackets removed and all flex cables disconnected you can now remove the motherboard. I recommend starting at the top (Rear facing camera side) and removing the board top down because the charging port sits in the frame of the phone and will come out more easily last.
  14. BlackBerry KEYone Motherboard Disassembly, Done!: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All done the motherboard is out. Revealing the vibrate motor and headphone jack.
crwdns2935229:022crwdne2935229:0
Nathan Albertson
crwdns2935283:008/06/15crwdne2935283:0
791 crwdns2915208:0crwdne2915208:0
#TomatoBetChallenge crwdns2935289:0#TomatoBetChallengecrwdne2935289:0
Business
crwdns2947412:07crwdne2947412:0
Do you have a source to purchase oem parts? (Those other than digitizer and keyboard)
mainely_linux - crwdns2934203:0crwdne2934203:0
Is it possible for 5ghz to have a separate antenna than 2ghz WiFi? And where on the board would it be? I just received a replacement and it won't hold a strong signal unless I hold the phone a foot above my router. Then it drops by 10+ meters for every inch a move it away.
Shane M. - crwdns2934203:0crwdne2934203:0
Could anyone tell me where the antennas are? and how they connect. I know something is supposed to hide behind the antenna bars on the chassi. but I dont see where it connects to these.
Hugo Danielson - crwdns2934203:0crwdne2934203:0
Can anyone tell me whether the two metal connectors above the vibrator motor are for wifi? One of mine came off when replacing the back cover (I do have it and believed it can be micro soldered) and since then my wifi has been sketchy. Thanks
Dee Jay - crwdns2934203:0crwdne2934203:0
Hey everyone I have started a new gardening project. If you got a minute check out this website I designed :-) https://tomatobetchallenge.wixsite.com/h...
Nathan Albertson - crwdns2934203:0crwdne2934203:0
Bought a screen for blackberry keyone and replaced the old broken now the backlight of the LCD won't come up. Help
John Okwerekwu - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 31,514
