crwdns2937539:0crwdnd2937539:0crwdne2937539:0
BlackBerry 7290 LCD Replacement
  1. BlackBerry 7290 LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 7290 LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 7290 LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. BlackBerry 7290 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. BlackBerry 7290 LCD Replacement, SIM Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. BlackBerry 7290 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. BlackBerry 7290 LCD Replacement, Side Button: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. BlackBerry 7290 LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. BlackBerry 7290 LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. BlackBerry 7290 LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. BlackBerry 7290 LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
  10. BlackBerry 7290 LCD Replacement, Keypad: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the phone's internals, start by loosening one side by pulling gently.
  11. BlackBerry 7290 LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With one side loosened, simply lift the phone internals to separate from the front casing.
  12. BlackBerry 7290 LCD Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the internals over to reveal the LCD display.
  13. BlackBerry 7290 LCD Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the rubber keypad buttons from the face plate.
  14. BlackBerry 7290 LCD Replacement, LCD: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate a hook on the right side of the internals below the volume wheel.
    • Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
  15. BlackBerry 7290 LCD Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry 7290 LCD Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the clip unhooked, gently separate the display from the phone internals by pulling.
kmathew
crwdns2935283:010/17/09crwdne2935283:0
3 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-6, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 19-6, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S19G6
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 6,039
