Learn how to manipulate your Black and Decker Toast R Oven in order to clean it, to replace its door-spring mechanism, and/or to replace its damaged door.
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Hi I am doing my own repairs on a black and decker toaster oven and need some help. identifying that part under the oven where the power cord enters the enclosure its actually a disconnect switch to disconnect the power when the door is opened.
Remove the metal vent piece that is below the door.
Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
Remove the crumb tray (the bottom, metal panel) from the toaster unit.
Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
Remove the knobs by pulling them upward; they should slide right off.
When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
Unhook the bottom of the the display panel from the toaster unit.
Begin to detach the back panel from the toaster unit.
Then, unhook the rest of the display panel.
Finish removing the outside cover by lifting the lid upward.
Remove the four Phillips #4 1 cm screws from the back of the unit.
All this to clean the crumb tray? Ridiculous! Is there not an easier way to take out the crumb tray?
Now, you can clean the outside units of the toaster oven.
Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
Remove the spring from the door mechanism by pulling it off.
Replace the old spring with a new spring.
Use the pliers and a wrench to straighten the outdoor mechanism.
Take off the left side of the door by separating the unit from the hinge.
Separate the right side of the door from the unit as in the previous step.
Separate the door mechanism from the door by tilting the door to relieve the mechanism.
sale humo al momento de prender el horno
Thanks - you guide helped me ix my toaster oven.
