Black and Decker Dustbuster CHV1510 Battery Pack Replacement
  1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six exterior 2 mm Phillips #0 screws securing the 2 halves of the white shell together.
  2. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove nozzle by pressing two blue buttons on the side of the nozzle
  3. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the dustbin by pressing the blue button on the vacuum's handle and lift the bin from the vacuum.
  4. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently separate the two halves by pulling them apart, revealing the 14 cell battery pack behind the motor.
  5. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removal of the battery pack is a tool-less process, lift the battery pack out of the vacuum gently, notice there are two wires connected to the battery.
  6. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the red wire from the battery pack (pull do not twist!) and do the same with the black wire
    This is removing the battery pack, not replacing the battery pack. That would be the interesting part.
    abrown - crwdns2934203:0crwdne2934203:0
    Okay then:
    Step 7: connect replacement battery pack to the battery terminals, taking note of polarity.
    Warning: if battery terminals are accidentally connected incorrectly in reverse polarity (i.e. black to red and vice versa) damage to the battery and device, and user injury may occur.
    Step 8: Reassemble device by following disassembly instructions in reverse order.
    Hope this helps.
    danger -
    Seems like a pointless excercise, as the original batteries are no good.
    I have had two 15.6 DBs, including a warranty replacement, and maybe got 5 uses out of them before the batteries failed.
    There are tips on replacing with NmH batteries on line, or get a new one with Lithium ion batteries.
    Peter Lech - crwdns2934203:0crwdne2934203:0
    I will second that. NmH batteries and maybe the charger are the problem, so it is pointless to thro more batteries in there.
    Hi Peter, thank you for the above comments. Do you have any idea where to buy a NmH replacement battery ?
    Jeremy Green -
    Where ww can buy the battery pack with the same specification.
    loewy41 - crwdns2934203:0crwdne2934203:0
    1. For the disassembly methodology, it would be better to remove the normally removable components first before removing the screws holding the motor/battery case together.
    2. The link provided for battery replacement is no longer valid. Since online retailer merchandise web pages change frequently and therefore links soon go out of date, it’s best to search for a battery replacement at the time needed rather than provide a specific link. Be sure to search for your exact vacuum model number since the installed charger has to be compatible with the battery type.
    Intercoaster - crwdns2934203:0crwdne2934203:0
    1. Despite understandable reservations as to quality, eBay often has a good selection of replacement batteries. Preferred sellers are US -based as opposed to offshore and those that allow returns. Specification is crucial: type, (e.g., NiCd, Li-on), voltage, dimensions (new battery must obviously fit into vacuum case), battery terminals (type must be compatible with existing wiring - check against seller’s provided photo). If in doubt, send seller a question via eBay.
    2. Check manufacturer recommendations for charging. Leaving a device permanently on charge when not in use may not necessarily be the best method for optimum battery life.
  7. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Holding the battery pack firmly, disconnect the red and black wires from the battery pack by pulling them gently.
    These directions are fine, but they leave out the most difficult part: finding a replacement battery. Nobody sells them, so you can follow these directions and get the battery out, but you won’t have anything to replace it with.
    Shopper Consumer - crwdns2934203:0crwdne2934203:0
Miguel Vilao
crwdns2935283:011/09/17crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
IUPUI, Team S7-G6, Baechle Fall 2017 crwdns2935289:0IUPUI, Team S7-G6, Baechle Fall 2017crwdne2935289:0
IUPUI-BAECHLE-F17S7G6
The battery pack in no longer available and the 14 cells would cost more than a brand new dustbuster (Feb 25, 2021). I managed to get almost 10-years out of my CHV1510.
glenn.watkins - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 4,518
